Testin phase
Started by sebaw, September 07, 2007, 03:22:19 PM
hansvonlieven
Beautifully built sebaw,
Best of luck with your experiments.
Hans von Lieven
sebaw
@JamesThomas and hansvonlieven: thank you very much for you kind wishes, tommorrow i am gonna try lighting a flame fot the first time...
hansvonlieven: i read your page about Keely, nicely done, i admire the work of keely and haven't seen better explanations of his devices then yours...
keep up the good work
SeBaW
hansvonlieven
G'day sebaw,
Just received this in the mail (I am on their mailing list) I thought this would interest you.
http://www.takeaction.com.au/hoh/hohnews/HOH_NEWS_09_07.asp
Hope it is useful
Hans von Lieven
Gheller J
Theres something wrong wit d dimensions you mentioned
outside tube: thickness = 1.5mm , diameter = 16mmÃ,  , length = 170mm
inner tube: thickness = 1.5mm , diameter = 13mmÃ,  , length = 180mm
gap between tubes = 1.5mm
Outer dia> 16mm - (1.5 + 1.5) mm thickness = 13mm inner dia of outer tube!
Your inner tube dia is 13 mm>>>>there shoulnt b a gap in between d pipes at all!! Actually if dats the case you cant put 1 pipe inside another!
It looks like u have around 2 to 3 mm gap b/w pipes for the pics.
Check ur dimensions again. :o
If d outer dia of inner tube is 1/2 inch  >> 12.7 mm then 1.5 mm gap is correct. Check d thickness of outer pipe for correct gap.
thickness>>
14 AWG = 1.626mm   15 AWG = 1.448mm   16 AWG = 1.295mm
16 SWG = 1.626mm   17 SWG = 1.422mm   18 SWG = 1.219mm
Gh. J.
hartiberlin
@sebaw
Well done !
Please be safe and use at least one or 2 bubblers after the electrolyser when you try out a flame
from your electrolyser.
Please keep us updated.
Many thanks.
Regards, Stefan.
