Chas Campbell Flywheel Generator
Started by wattsup, September 09, 2007, 12:42:30 PM
ken_nyus
Quote from: hartiberlin on September 13, 2007, 09:24:38 PM
Quote from: helmut on September 13, 2007, 04:46:37 PM
By the Way
I have to report,that the overunity.com Page was hidden about 6 hours ago.
There was a comment saying,~~~that the replays exceed the limit from 50000 on hartiberlin~~
more or less exactely.
helmut
Thanks for this report .
How long was it offline ?
I have to complain to my hoster again...
You should also change your error page, it exposes the value of the database userid, this is a security leak.
ashtweth_nihilisti
Guys here is the written report on the fly wheel tests we did.
Ill post the video here so we can stay on topic.
Duty cycle test results. [in short good and bad]
You guys will need to make up your minds if there is still something to salvage:
In our amp meters[digital not watt hour meters] pumped into the 240volt grid, Chas's original motor pulled 6 amps The RV [I AM NEVER WRONG ABOUT THE RV SO FAR) pulled 3 amps input [as i said it would]
The video will show a watt hour and our digital amp meters test,  our digital amp meters show myself pulsing out 2 saws, for 4 seconds on (put a stop watch on the video) and one second off as per Stefans request. Figures went negative [10 out 3 in ruffly], but the voltage most likely dropped.
Watch the video, a real load was pulsed and cut wood which drew around 10 amps [4 sec on and one off], RV stayed around 3 amps. How ever, as an engineer pointed out the voltage on the ALT Dropped, so would this 4 seconds of  ten amps still be usable in a useful applicaiton, you guys will have to decide, we have all the details now to reproduce his system.
Watt hour meters test, show  in run time after it took me along time to CHARGE up the fly wheel from the RV, that the run time tests and even pulse tests on the watt hour meters show no OU.
Total watt hour power consumed from the first tests, showed more energy to charge up the flywheel and pulse it out [total power consumed]. Check out the video. Now i am saying this as we did this on our amp meter and connected the watt hour meter, the actual watt hour meter test with out our amp meters showed similar figures of input and out put so please watch the video and make up your own mind.
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
hartiberlin
Hi Ash,
many thanks for this first report.
So where did you put the videos ?
Did you or anybody else also upload the removed video
again ?
Many thanks.
Regards, Stefan.
ashtweth_nihilisti
Hi Stefan, my assistant is editing them now for you guys, so i don't have them  :)
Should be up tonight or in the morning at the latest, Chas also explains another part of his gravity wheel on one of them, ill get the one removeduploaded also, the up loader had to change the description, so removed it ???
so 4 videos will be done.
1) duty cycle tests
2) Chas speaking a little bit about his wheel and concept
3) previous removed Chas video
4) panacea's production on the evaluation of the tests
hartiberlin
Many thanks Ash to you and your team and to Chas
for this big work.
Looking forward to see the new videos.
Regards, Stefan.
