Chas Campbell Flywheel Generator
Started by wattsup, September 09, 2007, 12:42:30 PM
ltseung888
Some more comparisons - already in the new Campbell5-1B.doc.
** If we compare the Chas Campbell Flywheel Generator with the 225 HP Pulse Motor, the following points should be noted:
(1)   One slice of the 225 HP Pulse Motor has eight Drive Coils that can also act as Pickup Coils.
(2)   The Program can change the amount of current to the Drive Coils; the number of Drive or Pickup Coils in the interaction
(3)   The Magnetic Field from the Drive Coils already increases the effective Gravitational Constant G. Thus tilting the axle will not lower the Lead Out Energy significantly.
(4)   Another Ring with a Magnet rotating could produce the Flying Saucer Effect.  Thus this is worth much more research.
(5)   Many slices can be put together (9 in the video shown).
Lawrence Tseung
Programs to modify the Pulsing Input Leads Out the desired Output.
RebeLLz
Man kann Energie nicht erzeugen, nur umwandeln.
Jason
Thanks for the link that is a very interesting concept
Jason
hansvonlieven
G'day Lawrence and all,
Assume that such energy can be drained or supplied within x sec, power  in Newton-meter/second (watt)"
4884.15252      if x =    3
and
The Energy drained or supplied at such high rotational rates is very different from what is experienced in daily life.
Regards,
Lawrence Tseung
What data lead to this rather wild speculation? What kind of energy are you talking about and how do you arrive at the formula?
Hans von Lieven
ltseung888
Quote from: hansvonlieven on September 23, 2007, 07:54:49 PM
4884.15252      if x =    3
and
Regards,
Lawrence Tseung
Hans von Lieven
Please see
http://www.overunity.com/index.php/topic,2794.msg51264.html#msg51264
for my reply.  I would like this thread to focus more on Chas Campbell flywheel discussions.
