WFC Tubes conditioning
Started by Duranza, September 10, 2007, 12:37:03 PM
Duranza
I'm using T304 for both tubes and my positive one is corroding with oxidation. I wonder if T316 would too.. If it doesn't I might have to try switching. I have heard that you can use titanium for the possitive and SS for the negative. I still got lots of experimenting to do.
The only way to Validate is to Replicate!
Duranza
Here is a picture of my bifilar pancake chokes between acrylic disks.
RunningBare
Quote from: Duranza on September 11, 2007, 02:40:57 PM
Now thats impressive!, can you explain how you wound it and the former you used?
Oh, and the number of turns including wire gauge please.
Duranza
I used 22 swg magnet wire bifilar wound with 100 turns. The coil was wound between 2 acrylic disks that are sandwiched with a  24 swg spacer in the center. It was real easy to do, and seems to reduce the amps big time. The positive side if the cell is connected to the one of the inside leads of the pancake and the negative is connected to the outside.
keithturtle
The bifilar choke has four leads, no?  And yer only using both ends of the same wire, outer edge and from the center?
Nice approach- wonder what the mag field looks like around it?!?
Turtle
Soli Deo Gloria
