Control Inside?
Started by BEP, September 11, 2007, 01:44:24 PM
MACEDONIA CD
HEY  TO ALL
  a like to say to all  everubody  is  put me down
but im  good man  and  i teling you    when  S.M said  earth elktromagne  fild  ho is move  the elktrones in the wire
for all ho whant to read  please
  S.M said  6000 cicle  <<6000Hz>>  whit  dc voltage    <<  way is teling this  >>  :o
i teling  you   if you have  a simple radio  FM  and find  where is not  be  a stations  i mean beatveane  2 stations    you can listen  a  noise  i   that noise  is  about  6000 Hz    anther time  i whill send  to all to see  way is like that  S.M said  his divices is like  a recivers  S.M  said  if you  tune  clouse to the raid frek  then hi whill get burn itself
i said  is like this if you have noise  6000  that nois  is smaler  voltage but  is constant  whit no   variable  voltage  ,, if  yo put in the raid fre.  whit  variable  nf nose   then whill hapend this
in 1 second  the voltage whill be a big  then in the  anther  second  whill be  small
that is the reason way is  a stability is hi divices is   if S.M catch  the raid station  his voltage whill be variable    A NOISE  OF 6000 CICLE  <<FREK.>>  IS PERFEKT  FOR THIS    DIVICES  NO VARIABLE
way dc voltage   the ansver  is  so simple  if you have  high frek  whit  audio  modulation  insaid  the high frek   yuo  put  only  a simple  diode  you then  whill separated  the high frek.   of  audio frek     the simple diode  whill be  to  provide  dc  voltage  from hihg frekk  , but  whit  6000  hz  insaid
imagen  if you have osciloscope  if you put dc  in to  the scale whill up  but if you put in this dc voltage  nois  whit 6000 hz  the  osciloscope be like this
the dc whill be  up of  +   whit  sinuse noise
is obviuse   is so simple    S.M  said
THE WIRE IS  IMPORTANT  AND COIL OPERATIONS  <<WAY>>  man S.M said golden  thing   if you thing  and thing  there is the ansver
in the  end i said this DC VOLTAGE  WHITT 6000 CICLE
                                 WIRE IS IMPORTANT   COIL OPERATIONS
                                EARTH ELEKTROMAGNET FILD
                                 TELLING  THE TRUE
MY LITLE HELP IS  IF YOU MUVE SMALL  MAGNET  WHIT HIGH SPEED  TO  A SIMPLE WIRE  YOU GET  THE MORE POWER   OF THE SIMPLE WIRE  <<<< IF YOU CHANGE  MAGNET  IN TO A HIGH SMALL ELKTROMAGNET WAVE  THEN YOU GET THE POWER  >>
VERY SMALL ELKTROMAGNET WAVE  WHIT HIGH SPEED  IS LIKE  BOMB   YOU THEN  WHILL MOVE ELEKTRONES WHIT  VERY HIGH SPEED  IMAGEN THIS  IS NO NEED BATERY FOR  THIS DIVICES   HI ONLY  NEED A ELEKTROMAGNET  WAVE  WHIT VERY VERY SMALL OR MICRO VOLTAGE  BUT  MUST BE WHIT  HIGH FREK  .. THEN YOU GET THE IF YOU NEED  A 1000 OF AMP   HAT IS THE ANSVER   TO ALL  SECRETS  OF DIVICES
S.M  is teling the true  but whit  secret in his worlds  the key is thi
EARTH ELEKTROMAGNET WAVE
WIRES  IS IMPORTANT  COIL IN OPERATIONS
AND 6000 HZ  WHIT DC VOLTAGE
I  WHIL SEND TO ALL TO SEE  THIS   IN THE VIDEO CLIP TO PRUVET  HIS DIVICES  IS  POSIBLE  AND IS SO  SIMPLE    SEE YOU  AND THING IF YOU ANDRSTEND SOME OF THIS  I HAVE TELL YOU  NO BATERY NO CIRCUITS WHIT TRASISTORS  ONLY WIRES  AND COILS  WHIT DIODE  THAT IS ANSVER
BY FROM MACEDONIA
EMdevices
Hi Macedonia CD,
I like what you are saying !!Ã,
I hope you don't mind, but I want to retype your text.Ã,  It helps me understand it better as well.Ã, Ã,  You are improving your English and I admire your efforts to type in another language, so continue posting.
HEYÃ,  TO ALL,
IÃ,  would like to say to all,Ã, Ã,  EverybodyÃ,  isÃ,  puting me down !Ã, Ã,
But I'm a good man,Ã,  andÃ,  I'm telling you thatÃ,  whenÃ,  S.M says:Ã,  "the earth's electromagneticÃ,  fieldÃ, Ã,  is movingÃ,  the electrons in the wire"Ã,  (he means it)Ã, Ã,  Ã,  For all that want to read (his words/letters to verify the statement),Ã,  please do.
S.M mentionsÃ,  6000 cyclesÃ,  << or 6000 Hz>>Ã,  with a dc voltageÃ,  Ã,  <<Ã,  why is he saying this?Ã,  >>Ã,
I'm tellingÃ,  you thatÃ,  if you haveÃ,  a simple FM radio,Ã,  and tune it to a spot where there are no stations, I mean right between 2 stations,Ã, Ã,  you can listen and hear aÃ,  noise ofÃ,  aboutÃ,  6000 Hz !!!Ã,  Ã,  Some other timeÃ,  I will send (or post) more info so you can all seeÃ,  why that is.
Now,Ã,  S.M saidÃ,  his device is likeÃ,  a receiver, also,Ã,  S.MÃ,  saidÃ,  if youÃ,  tuneÃ,  too close to the right frequencyÃ,  then you run the risk of getting burned.
Ã,
I sayÃ,  it's like this:Ã,  if you have noise of 6000 Hz,Ã,  that noiseÃ,  is a smallÃ,  voltage butÃ,  constant,Ã,  with no variableÃ,  voltage.Ã,  IfÃ,  you put in the right frequency,Ã,  with this variableÃ,  Rf noise,Ã,  then this is what will hapend:Ã,  in 1 secondÃ,  the voltage will be bigÃ,  then in anotherÃ,  secondÃ,  it will beÃ,  small.
That is the reason way there is instability in his devices.Ã,  Ã,  It's becauseÃ,  if S.M catches, or tunes to the right station,Ã,  his voltage will be variable.Ã,  Ã,  A NOISEÃ,  OF 6000 CYCLESÃ,  <<or FREQUENCY.>>Ã,  IS PERFECTÃ,  FOR THESEÃ,  Ã,  DEVICES,Ã,  NO VARIATIONÃ,  !!!
Why a DC voltage?Ã,  Ã,  Ã,
The answerÃ,  isÃ,  so simple,Ã,  if you haveÃ,  high frequencyÃ,  withÃ,  audioÃ,  modulation,Ã,  insteadÃ,  of the high frequency alone,Ã, Ã,  you can put (or insert)Ã,  onlyÃ,  a simpleÃ,  diode to separatedÃ,  the high frequency from theÃ,  audio frequency.Ã,  Ã, Ã,  The simple diodeÃ,  will beÃ,  toÃ,  provide (or separte)Ã,  the DCÃ,  voltageÃ,  from the high frequency, butÃ,  withÃ,  the 6000Ã,  hzÃ,  instead.
Ã,
Imagine if you have an osciloscope.Ã,  If you put DC in to scale, it will go up,Ã,  but if you put in this DC voltageÃ,  noise of 6000 hz,Ã,  theÃ,  osciloscope will be like this:Ã,  the DC will be up ofÃ,  (+)Ã, Ã,  with the sinusoidal noise.Ã, Ã,  It's obvious !!Ã, Ã,  It's so simple !!
S.MÃ,  said:
THE WIRE ISÃ,  IMPORTANTÃ,  AND COIL OPERATIONSÃ,  Ã,  Ã,  Ã,  <<WHY (did he say that)??>>Ã,
Man, S.M said a goldenÃ,  thing !!!Ã, Ã,
If you thinkÃ,  and think about it,Ã,  there is the answer !!!
In theÃ,  end, I say this:
1)Ã, Ã,  DC VOLTAGEÃ,  WITH 6000 CYCLES
2)Ã, Ã,  WIRE IS IMPORTANT,Ã, Ã,  COIL OPERATIONÃ,
3)Ã, Ã,  EARTH ELECTROMAGNETIC FIELD
4)Ã, Ã,  SM IS TELLINGÃ,  THE TRUTH
Ã,  Ã,  Ã,
MY LITTLE HELP ISÃ,  THIS:
IF YOU MOVEÃ,  A SMALLÃ,  MAGNET,Ã,  WITH HIGH SPEED,Ã,  PASTÃ,  A SIMPLE WIRE,Ã,  YOU GETÃ,  MORE POWER FROM THE SIMPLE WIRE (then if moved slowly)Ã,
<<<< IF YOU CHANGEÃ,  THE MAGNETÃ,  INTO A HIGH SPEED SMALL AMPLITUDEÃ,  ELECTROMAGNETIC WAVE,Ã,  THEN YOU GET LOTS OF POWERÃ,  (due to the speed of light the waves are traveling at) >>>>
A VERY SMALL ELECTROMAGNETIC WAVE,Ã, Ã,  WITH HIGH SPEED,Ã,  IS LIKE A BOMB !!Ã,  YOU THENÃ,  WILL MOVE ELECTRONS WITHÃ,  VERY HIGH SPEED !!Ã,
IMAGINE THIS:Ã,
THERE IS NO NEED FOR A BATTERY, FORÃ,  THESE DEVICES.Ã, Ã,  HE ONLYÃ,  NEEDS AN ELECTROMAGNETICÃ,  WAVEÃ,  WITH A VERY VERY SMALL, OR MICRO VOLTAGE AMPLITUDE,Ã,  BUT IT MUST BE WITH A HIGH FREQUENCY.Ã, Ã,  THEN YOU GET THE CURRENT YOU NEED !!Ã, Ã,  THE 1000s OF AMPS!!!Ã, Ã,
THAT IS THE ANSWERÃ, Ã,  TO ALLÃ,  THE SECRETSÃ,  OF HIS DEVICES !!Ã,
S.MÃ,  is teling the truth,Ã,  but withÃ,  secrets in his words !
The key is this:
1)Ã, Ã,  EARTH ELECTROMAGNETIC WAVEÃ, Ã,
2)Ã, Ã,  WIRESÃ,  ARE IMPORTANT,Ã,  COIL OPERATIONÃ,
3)Ã, Ã,  AND 6000 HZÃ,  WITH DC VOLTAGEÃ,
IÃ,  WILL SEND TO ALL TO SEEÃ,  THIS IN A VIDEO CLIP, TO PROVEÃ,  HIS DEVICESÃ,  AREÃ,  POSSIBLEÃ,  AND SOÃ,  SIMPLE,Ã,  SO YOU CANÃ,  SEEÃ,  AND THINK IF YOU UNDERSTAND SOME OF THIS.Ã, Ã,
I HAVE TO TELL YOU,Ã,  NO BATERY, NO CIRCUITS WITH TRANSISTORS,Ã,  ONLY WIRESÃ,  AND COILSÃ,  WITH A DIODE.Ã,
THAT IS THE ANSWER !!Ã, Ã,
BYE from MACEDONIA
BEP
@MACEDONIA
I agree with your thoughts. I believe no control circuits are needed to produce this energy.
I also believe control is needed to prevent the 'bomb' effect you mentioned. It is not difficult to wind coils that produce voltage. The difficulty is when you finally understand how you then realize what happens when it runs away!
Any controls I make are for two purposes.
1. Get it started.
2. Keep it from blowing up  :)
I can't wait for your video or any other thoughts!
otto
Hello all,
yes, and with a Mobius....
Otto
mkt3920
Quote from: otto on September 13, 2007, 01:55:16 AM
Hello all,
Otto
Interesting mobius page and speaks of interacting with earth's magnetic field.  Pic looks like mobius wind for the control coils rather than the collector coil.  What if both type coils were mobius wound?  Mobius coils creating mag fields on a mobius strip?
   http://jnaudin.free.fr/html/tripole.htm
Kent
