An idea I wanted to get some feedback on
Started by erickdt, September 11, 2007, 04:13:32 PM
fletcher
I should think that back torque against the ramp will kill this design - nice presentation btw.
Here is something similar but with less moving parts.
erickdt
Quote from: fletcher on September 12, 2007, 03:55:56 PM
Hmmm, <strokes non-existant beard>... Thanks for the info. The difference between mine and this one is that the weights in mine transit over the rotational axis. By the time any particular arm reaches the 7:30 o-clock (negative 45 degrees) point the weight on that arm (theoretically) is located directly centered on the rotational axis thereby having a null effect. This way there is no weight what so ever to the left side of the rotational axis on any arm past the 7:30 o-clock point (negative 45 degrees) theoretically taking any counter clockwise torque out of the equation all together. Thoughts?
Joh70
very fine drawings! Congratulations to your AutoCad-experience. When balanced right thru best geometry and identical weights and levers, which is difficult enough, the only thing what happens will be: it turns one stage from 8 (no total revolution), then it rests. the best you can get, is a configuration which allows to overcome each stage at lowest possible resistance under influence of an external force. no endless motion here.
mapsrg
When you consider the amount of linear motion required on each rotation of each arm there is alote of lost energy....
