ER1200 water torch
Started by Prophmaji, September 12, 2007, 09:55:07 PM
Prophmaji
Here's a shot....of one of the less interesting ones
mikestocks2006
Quote from: Prophmaji on September 14, 2007, 11:02:21 AM
water and metals are difficult to heat.
High resitstance materials heat INCREDIBLY fast.
I've had magnesium alloy glow super white hot, like a solar flare....but NEVER dissapear or melt. It bubbles to a foamy like  material, about three times it's original size.It goes to being like a little light rock, to being like a mini-wheat cereal bit. (ie foamed corn syryp and solids)
Glass, being of high resistance, practically explodes as the 'flame' touches it. Quartz does the same.
Water will boil away very very slowly. I've spent over 1/2 hour attempting to boil a cup (8 ounces/250-275ml) of water. This is seemingly due to it being conductive and a hydrodynamic fluid.
Copper, steel, but most specifically pure elements, are the hardest to heat. Most specifically, elements that are electrically transmissive in their solidus phase.
Ceramics, etc, anything highly resistive, and has a high resistence in the liquidus phase (above melting point) are nearly explosive and emit great huge gobs of white light, ie, incredibly bright. With the right light sensor and neutral filter...it can be used to do element analysis. The kind that cannot be done in any other way.
Tungsten goes to it's oxidized phase immediately, and the rest of the rod remains unchanged. Only the tungsten immediately near the flame is oxidized,and turned into a oxide and 'gas'. So, it's a very, very, very slow -'straight to gaseous phase' situation with tungsten. Which supports the idea that HHO CANNOT sublimate tungsten, or, that it does..but ONLY via oxidation.
Everything indicates that it actually IS a 'molecular spin down' plasma energy that heats via 'ajacent to that molecule it is tearing apart' - thermal addition.
What I mean is that the material being worked on by the 'flame' in the immediate sense, tears away from the main mass, is oxidized, via this 'molecular spin down effect' and the thermal effects are occurring in the ajacent molecular structures, via radiation from the materials that are being broken down. The evidence of the tungsten rod supports this effect, same as that of water.
I've created some bizzare alloys via this device, even rubies when messing with copper and silicates.
Ie, glassy copper alloys Or, if you will transparent copper.
The HHO gas returns to atomic from expanded mono-atomic state-electrical plasma flame-but at at individual atomic structure dynamic fluid state effect, thus the 'flame' effect.
So, an electrical fluid propogation through the expanded gas, as a 'shock wave'....popping all the gaseous expanded HHO, in a dynamic flow fluid effect. The flame is electrical in nature, and it is energy release from the reduction from expansion back to the 'normal' state. HHO self collapes, above about 21 PSI. It is quite explosive at this point but it is a collapsing effect, endothermic, not exothermic. The plasma flame that HHO is, has been found to run at about 8500m/second. (the collapsing wave function of the electrical transfer in the expanded fluid)
Hi Prophmaji,
Nice tests
Have you tried a container eg a cup of some sort, made of a high resistive material, where there is water in the cup, and torch the bottom or sides of it?
Will you get the water to boil fairly fast due to the heat conduction from the cup walls to the water?
A possibility of ?low energy input via HHO? to boil -> steam water etc?
Thanks
sebaw
Quote from: Prophmaji on September 20, 2007, 10:47:05 AM
Thanks for the picture Prophmaji, that's copper and glass together, right ?
sebaw
Prophmaji
Quote from: mikestocks2006 on September 20, 2007, 11:28:40 AM
Hi Prophmaji,
Nice tests
A possibility of Ã,“low energy input via HHOÃ,” to boil -> steam water etc?
Thanks
Yes. Abundantly so, IIRC. Wether it is efficent to do so, is an expereniment I've not done. Not likely to do it soon either. The flame will eat any container the water is in.
I'm off in a different direction; I'll leave that one to the interested. :)
btester1
hho is claimed to reduce radioactivity.
I would like to see this experiment.
Get a geiger counter with various radioactive compounds.
Test radioactivity before and after. You can get a geiger counter off of ebay for under 100 bucks.
Would be very interesting.
You would cause a controversy. This is something physics couldn't explain.
At least I've never heard of something that effects radioactive decay rates.
