electric generating magnet motor, maybe kinetic too
Started by ckm, April 03, 2005, 02:43:14 PM
0 Members and 42 Guests are viewing this topic.
ckm
This is an idea based on magnetic repulsion ( to move the magnets using their own attraction-repulsion towards each other ) and that passing a magnet over conductive wire produces a current.
Again - not tested. So no ratios for spacing of magnets, or of the inner to the outer wheel sizes upon which they are to be affixed, or what magnet strengths.
When that is sorted out tho', the moving wheel (doesn't matter if inner or outer) will rotate one way then be repulsed back the other way, in theory for ever.
The conductive wire is wound within the two wheels or in such a way as to keep generating current - it needs to pick up from the moving magnets.
neutrino
Whenever a current is induced in the wire a back emf (reversed electro magnetic force) will prevent the magnet movement in at least 100% of the electric possible outtake, see Lenz law:
http://www.launc.tased.edu.au/online/sciences/physics/Lenz's.html
So in any conventional construction the "Perpetual" effect will fail!
Unless you dont find a way to place a  magnetic field in to a coil without the typical Movement...
irisher
Similar theories have included harmonic balance wheels, pendulums and even planetary gear sets with magnets and coils placed in either a rocking repulsion or a rolling attraction. The aforementioned Lenz Law ,friction, and gravity have always been the demise of these designs. But getting people to think of designs is ( I think) the key purpose of this forum.Right ones will be explored. Ineffective ones will be explained away by the various members with their combined experience. Keep thinking of more! ;)
TechStuf
Considering that the 'hallowed' halls of science still (quite intentionally imho) depict the magnetic field model of a common dipole in the senseless and misleading way that they do.....I am afraid that pure, unadulterated frustration will be the soup D'jour ad nauseum, for many would be 'gate crasher' technophiles.
Once a true and accurate dipole model is publically shared and verified....then what walls will stand?? What gates will not swing inward?
I would posit that, just One wall, One gate would hold on that day.
More soup for everyone!
Except you.......NO SOUP FOR YOU!
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
Thaelin
   Here in lies the bigest problem with mainstream science. They refuse to thinik outside the box.
What will happen if you do make one. Then you will be laughed out of the hall so to speak. There
are scientists that have tried and ruined their carrers over it. The "laws" are set in stone and can
not be changed. Anyone who can prove a change still has a long hard road to travel. We dismiss
your findings as bogus and unacceptable by current theroms is the usual reply.
   Then on the other side we have all the claims that can not be tested or will not be allowed to
be tested fueling even a bigger fire.
sugra
