Circuit setups for pulse motors
Started by Nastrand2000, September 16, 2007, 10:46:33 PM
0 Members and 57 Guests are viewing this topic.
Ren
Oh jase by the way, Id love to see you add another coil to your setup, doesnt even have to be pulsed, can just be a pickup maybe? Id be interested to see what sort of voltage comes off the secondaries. Also, maybe try same test with iron or tie wire core coil and air coil, I would like to see if there is much difference between. I understand though if you dont, that coil better be bolted to the floor with those neos!
Nastrand2000
Hey Ren,
I do charge the 9 volts to around 11 or 12 volts and they do settle around 9 volts or so. I have found that their life is significantly shorter then a new 9 volt however. I would think that you could probably get one good charge on them. Mine have been recharged countless times, so this probably is also a factor with mine. I will see what I do with the different coil setups, probably this weekend, I have a o chem test today.
Jason
Nastrand2000
Hey Ren,
I hooked up one of the coils as a generator coil and ran my motor at 5 volts .05 amps. The coil generates about 15+ volts into a cap 35mF cap 370 volt rating. With a 25 volt  3300 mF cap, It charges it too 14.5 volts. This is while I'm charging a 9 volt battery, I can't go without a load on this setup. The spikes are too high (like 300 to 400), I don't want to inadvertently fry something  like my power supply. It cost me around a 170$.
Jason
Nastrand2000
I'm also thinking about building my own batteries to better understand the reaction going on in them.
Jason
Nastrand2000
I think I'm about done in this thread with pulse motor recapture. I built this motor to drive a whimhurst machine and see what I can do with 40000 volts and I now believe that I can give it the torque that is  necessary to drive it. I believe that the plasma of the arc holds the key to our energy issues. I will be around if anyone needs more input.
Jason
