Circuit setups for pulse motors
Started by Nastrand2000, September 16, 2007, 10:46:33 PM
0 Members and 47 Guests are viewing this topic.
Ren
Quote from: Nastrand2000 on October 04, 2007, 08:35:34 PM
Hey Ren,
I hooked up one of the coils as a generator coil and ran my motor at 5 volts .05 amps. The coil generates about 15+ volts into a cap 35mF cap 370 volt rating. With a 25 volt  3300 mF cap, It charges it too 14.5 volts. This is while I'm charging a 9 volt battery, I can't go without a load on this setup. The spikes are too high (like 300 to 400), I don't want to inadvertently fry something  like my power supply. It cost me around a 170$.
Jason
Interesting. How many turns on the generator coil? Air coil? Hook it up to a bridge and see how many volts it produces....
I gotta start winding a large coil, I think thats the only thing holding my design back right now. I just cant scrape the funds together and renovate the house at the same time! Oh well, patience is a virtue.. ::)
Jase, good luck with your classes/exams, hope we still see you from time to time in here.
Nastrand2000
Ren,
The coil I was using for the gen coil is the coil used to drive this motor http://www.youtube.com/watch?v=tIOdl7H6qzA&eurl=http%3A%2F%2F7%2Egmodules%2Ecom%2Fig%2Fifr%3Furl%3Dhttp%3A%2F%2Fwww%2Egoogle%2Ecom%2Fig%2Fmodules%2Fyoutube%5Fvideos%2Exml%26nocache%3D0%26up%5Fprefs%5Fversion%3D
It is an air coil run through a full wave bridge rectifier. I don't how many turns, however it is bifilar wound 24 gauge and 2 inch in diameter by 3/4 inch thick. Hope that helps.
Jason
Nastrand2000
After further study I have found some interesting phenomena with stacked gen coils and driver coils (stacked together resonating together with alternating magnets passing) that may be of some service to those looking at the field of coil resonance vs. output.
Jason
Nastrand2000
This might further my research into these stupid pulse motors :P god only knows how much time I've spent on them. Very interesting to say the least. A video soon of this setup.
Jason
Nastrand2000
I just tried running my setup at 12 volts, it's too much for the transistor ( you could stack them to help....but you lose efficiency by doing that).
Jason
