Circuit setups for pulse motors
Started by Nastrand2000, September 16, 2007, 10:46:33 PM
Nastrand2000
Some really strange things have been happening while working with this setup. I will update a little later if I can figure out their cause. This is the type of accidental discoveries we all dream of. Don't worry about patent BS, This will be open sourced.
Jason
Nastrand2000
The nearest I can place this phenomena is the splatter coil by konzen but it reaches much further. An interesting effect that I think the "bowl" recapture can take advantage of. Sort of like a copper faraday cage. Move those electrons.
Jason
Ren
This is awesome news Jase I hope it works out and you get the results you're hoping for. Test it every way you know how!
Also, I'd like to see you run the motor off one battery and charge another battery the same size. This would be a good test to eliminate the power unit you run  it off. Have you tried charging Ni-Cads or Ni-Mh before?
Nastrand2000
I need to get a few test batteries to start some charge vs. discharge test results.
Jason
Nastrand2000
For all those out there looking to replicate this setup, I encourage you  endeavor to learn a better understanding of dynamic flow of electrons (virtual particle flux (within our time frame), particles that exist within our dimension and outside of it at the same time). Further more, one should look at wave functions( of virtual particles)  correlating to theses wave functions to fully realize the full potential of these motors/generators on everyday occurrences in our everyday appliances.
Jason
