Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
giantkiller
This thread will substantiate the progress of the amplifier and coil build. LOTRs curent status is holding up forward momentum which equates a lack of growth. Great history. Maybe this can be folded back into there. I need to post to grow. Must be the artist in me.
I post a diagram on history of some events we have all seen. They entail heterodyning and the outcomes. Enjoy.
There are 2 pathways. Edison and Tesla.
I pulled another power supply and a single channel 3w amp from my dark inventory.
In the pix I show 3 signal paths.
A1 = the xr2206 to the Bose. This output is sweet.
A2 = the ad826 board attached. The xr2006 gets nasty.
A3 = the http://www.kitsrus.com kit47 signal gets nasty also.
A4 = I move the kit47 into the picture and the signal gets sweet. HuH?
A5 = I search for small noise on xr2206.
A6 = I see it now I need to find it.
2 problems exists here. Noise, could be ground loop or floating ground somewhere. I moved the kit47 and the really bad signal went away. Too many jumpers!.
So this is my course this weekend.
jack81
Ehm...audio? What are you doing with audio? I don't understand.  :-[
giantkiller
Quote from: jack81 on September 22, 2007, 01:05:03 PM
I am setting up a platform for audio heterodyning. Then replace the speaker with the TPU. Look a the previous diagram. It shows all the necessary steps to experience the mixing of the 3 freqs to produce the rogue wave.
The heterodyning happens in the circuit, then we move it into space with a magnetic transmission media and give it dimension.
Safety first, results later.
--giantkiller. Telsa said sine waves.
ps:
LETTER  &  POEM  FROM  DONALD  P.  WALTON From:  NEN,  Vol.  4,  No.  2,  June  1996,  pp.  19?20.
New  Energy  News  (NEN)  copyright  1996  by  Fusion  Information  Center,  Inc.
The  quatrain  previously  submitted  was  inspired  by  the  description  of  an  experiment  undertaken  by  a  good
friend  formerly  residing  in  Hawaii.  He  is  an  excellent  engineer  and  also  has  many  of  the  gifts  associated
with  Edgar  Cayce.  So  when  he  told  me  that  this  project  arose  from  intuition,  and  had  been  undertaken
successfully,  I  was  cautiously  optimistic.  I  am  sure  he  would  feel  that  information  freely  given  is  meant  to  be  shared  internationally.
From  the  quatrain  many  references  are  quoted  which  were  studied  by  myself,  e.g.  Worrell?Keeley,  Tom
Beardon,  Bhuddist  and  Hindu  philosophy,  plus  many  fringe  science  papers  including  publications  on  how  the  pyramids  were  really  built  and  references  to  levitation  by  Bhuddist  monks  of  Tibet.  The  NASA  technical  briefs  on  levitation  were  also  investigated.  If  you  assemble  all  the  pieces  of  a  jig?saw,  then  the  whole  picture  is  presented.
At  this  point  a  few  extracts  from  his  letter  would  seem  appropriate:
"Each  energy  level  has  three  unique  frequencies,  also  due to  the  constructive  and  destructive  interaction  of  the  three  frequencies  produces  a  specific  composite  energy  level."  The  levels  may  be  designated  1  through  4, with  1  being  the  highest.  For  our  purposes  the  frequencies  are  not  important  (they  vary  from  1021  to  1024). What  s  important  is  the  relationship  these  frequencies  have  to  each  other  within  their  respective  energy  levels.
By  interfering  the  frequency  relationship  of  the  highest  energy  level  such  that  the  particular  frequencies  we  choose  generate  earth  resonances  as  one  of  its  heterodynes,  we  can  create  a  most  powerful  field  that  actively  interferes  with  the  earth's  magnetic  envelope.
The  frequency  ratios  of  that  level  are  1;4;  and  5,  or  in  musical  terms:  do,  fa,  so.  By  selecting  as  representative  frequencies  48Hz;  64Hz;  and  72Hz  ?  but  moving  the  three  down  just  a  hairsbreadth  so  that  the  heterodyne  of  the  two  highest  frequencies  becomes 7.83  Hz,  we  achieve  just  that.
Since  the  quality  of  the  actual  energy  level  is  that  of  Scalar  Standing  Waves,  longitudinal  in  nature,  using  sound  waves  can  simulate  or  mirror  their  interaction  if  the  medium  through  which  we  convey  them  is  ionic.
I  set  up  a  waveguide  with  three  arms  converging  to  a  center,  each  on  a  120  degrees  leg.  Each  leg  was  cut  from  square  cross?section  PVC  gutter  pipe  and  measured  to  correspond  to  an  exact  fraction  of  the  wavelength  for  one  of  the  frequencies,  that  is  12,  9  and  8  inches  or  multiples  thereof.  Transducers  capable  of  producing  120dB  in  the  medium  selected  must  be  used  and  these  are  placed  at  the  ends  of  the  cavities.  Measurement  is  done  from  the  face  of  the  transducer  to  the  point  of  intersection."
Generating  the  required  frequencies  is  relatively  straightforward  and  we  should  start  with  a  master  oscillator  with  fine  incremental  tuning  operating  at  576Hz,  this  is  coupled  to  three  buffer  amplifiers  whose  outputs  are  taken  to:  1.  A  divide  by  8  which  =  72Hz  2.  A  divide  by  9  which  =  64Hz  3.  A  divide  by  12  which  =  48Hz. All  three  are  then  taken  via  a  square  to  sine  convertor  and  to  the  transducers  via  power  amplifiers.  Not  being  partial  to  noise,  not  least  3  x  120dB,  I  am  considering  the  possibility  of  alternatives  to  the  above.  Do  beware  of  "Pop"  music  groups  standing  in  a  circle,  do  not  stand  at  the  focal  point  or  you  might  just  become  closer  to  heaven  than  you  would  wish.
**No  claims  are  made  by  myself  and  the  above  is  passed  on  purely  as  a  gift.  On  the  basis  of  my  own  investigation  I  would  suggest  there  is  a  better  than  average  chance  of  success.
Yours  sincerely,  Donald  P.  Walton
A Quatrain for Today's Boffins
(Can anyone rise to the challenge?)
In ancient times monks of Tibet
With music found that they could get
Rocks and stones to levitate
Against the laws of gravitation
In disbelief by western nations.
Around about 1895, a Keeley boffin did arrive, It's elementary, you must be fools,
It's all related to intervals.
Not only that, but he had a notion,
How to create perpetual motion.
Some years later the American nation
Saw in print this revelation.
The government were not impressed,
They declared it SECRET with great zest.
It is quite laughable to say
I was attempted by N.S., S.A.
From what they published there's no doubt They haven't much to shout about.
THESE MONKS KNEW A THING OR TWO.
Three frequencies must be played in bursts, All three below 100 Hertz,
And if you've got the signals right,
You will behold a wondrous sight.
REMEMBER THE INDIAN ROPE TRICK.
Although it has not yet been stated,
Schuman frequencies are related.
Combine this with what Keeley said,
See objects float above your head.
To get results don't throw the dice,
Geometry must be precise.
If you would rise above your station
Be sure to use the right equation.
Think carefully, don't be naive,
Standing waves you must achieve.
Tonight before you go to bed
Think on what Tom Beardon said.
If you would build a pyramid
Do what the Tibetans did.
I'm sure by now you all well see
A need for mental agility... May the FORCE be with you..
Donald  P.  Walton
(Apologies  to  Nostradamus)
bolt
GK whats the output of the mosfet amp like? Is it the one i showed the circuit for? Also did you test in to speakers first your best sound track will let you know how clean as well as injected sine waves im hoping the sound was fantastic with no noticable distortion and clean sound.
giantkiller
@Bolt,
I have noise coming from somewhere. I stripped all the modules apart and am mounting everything down mechanically. Then I will reconnect all back together. By your lead and some of my own thinking here is proven the functionality of the different modules. I have to clean things up a bit or the mess will become an inherent whole of the testing. Just have to anihilate that or do battle with that. We'll be just goofin around with stupidity forever.
When the ad826 worked it was nice.
I am off to the store to get parts.
-giantkiller. New thread, new start. More than one way to skin a server.
