Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
Feynman
Haha you are clueless poynt
Don't criticize what you can't understand.
poynt99
giantkiller
There are experiences in Overunity by alot of people. All valid. It is a strange place due to sometimes esoteric explanations. This doesn't come out of academia.
So I'll put this harshest of warning in the plainest of english: 'If you produce a video of a valid working unit, you are as good as dead'.
Who ya gonna call? Think about that! You gotta go somewhere with it. But where? This subject has also been covered. There is alot turf besides just this little patch.
The explanations come in EE, PHD, Physics, medical terms. I was early in the game when threads were few. I was lucky. Read and build. If you can't show any physical evidence then you have no right to critisize. Fair?
There are too many threads to read which is sad. I suggest to anyone who gets here to read what DFRO posted:
Here it is:
http://www.overunity.com/index.php/topic,3660.msg61477.html#msg61477
QuoteHello fellow reverse engineers.
I have been following this forum, watching the videos, and pondering how the TPU works.  I think it is an authentic freedom energy device.
I consider myself very much a novice in electronics, but maybe my conjectures could shed some new light on the "guess what answer I am thinking of" game we are all trying to play here with SM.  Please, pardon any major electronics dumb statements I make that reveal my inexperience in this field.  I hope my thoughts are not too disorganized and hard to follow, also.
I would like to start by commenting about the "rotating magnetic field" mystery.  I have been thinking a lot about that.  What I think is happening is SM has set up sets of inductive coils that are oriented in two, possibly three different directions.  On his small device there is the collector coil, which is wrapped around the circumference of the main circle.  I think he has wrapped the collector coil around the circumference several times, but since the wire strands are packed in with no kind of wrapping orientation (the strands are not wrapped side by side along a core or hollow tube), the magnetic flux lines look like they would be for a single strand. However, he has augmented the collector coil with other vertical coils, which seem to be wrapped around metal cores (and on which he placed the magnets in one video).  These windings could be extensions of the collector coil and connected in series with it and each other.  The input coils are oriented in such a way that their flux lines are 90 degrees to the output coil and vertical coils.  Again, I think the collector coil is somehow wired in series with the vertical coils.  Other sets of coils, which I don't see in any of the pictures could be oriented as if the windings were wrapping around imaginary wheel spokes.
I also think this device is harnessing and augmenting the radiant energy surges that come from very quick, high voltage pulses.  I remember Bedini or Tesla or Bearden saying that the more resistance across the voltage spike, the more electrons that piles up on the negative side of the circuit being excited.  The trick is to let the electrons pile up and then switch them into the circuit without destroying the dipole .  The inductive coils seem to be perfect for this.  The voltage spike hits the input coil, the high inductive reactance resists electron flow and then as the magnetic field builds and collapses, the electrons move.  I think he has all of the coils attached to capacitors to create resonant tank circuits.  Also, I think he might have a diode in series with the capacitors of the tank circuits so that the current can only flow in one direction (maybe not, though).  No current is ever allowed to flow when the pulse hits the coil.  The kick hits a back-emf wall when it occurs, pulls in the radiant energy current surge, and then lets the current flow in the input coil when the induced magnetic field is building and decaying.  With the current flowing in the input coil, its magnetic flux induces a current and flux in the collector coil.  Using the flux created in the collector coil is one of the secrets, I think.
I also think he is using a small battery in all the devices to run the pulse control circuitry.  I imagine there are a few 555 ic's that are driving some kind of fast, high voltage mosfet driver to make 1 to 4 sets of very fast, short on-time pulses, which are harmonics of each other.  I would suggest doing pulse ratios that are in the Fibonacci series or each pulse being the previous pulse times phi.  However, the pulses may be tuned to a chord, like a major chord - root, fifth, octave, tenth (just a thought).  He has written about striking the right chord, correct?  I also think he has a solid state diode/cap circuit to step up the voltage from the battery for the pulses.  I remember reading about how to do this using diodes, caps, and pulses - it is basic stuff, which I don't know how to do yet.
When the fast, high voltage kick hits the first input coil and inducing current, its flux lines build and cut through the collector coil, causing current to be induced in the collector coil.  It also induces current in the vertically oriented coils that are adjacent to the first input coil.  I imagine that these are wired in series with the collector coil. The magnetic flux has just spun 90 degrees and moved over from input coil 1 to vertical collector coil 1.  I also imagine that the adjacent vertical coil is wrapped in such a way that it induces a current (and thus magnetic flux)  in the second input coil.  So when the now faster (1.618: 1 faster?) kicks hit the second coil, there is already current moving and flux building.  The second input coil is also attached to a resonant tank circuit which is tuned to have its resonant peak at the frequency of the pulses. I think the collector coil and its vertical coils have caps in series, also.  They form part of a LC resonant tank circuit but also store the voltage to power any attached load.  It think the collector coil with the vertical coils is tuned to have its resonance at the lowest fundamental frequency, and the input coils are harmonics of that - possibly odd order harmonics, Fibonacci series, phi, major chord, or empirically tuned by watching the behavior on a scope.
When the kicks on coil 2 pull in the radiant energy current surge, that induces current and flux in the collector coil and the next adjacent vertical coil, which is wrapped in such a way that it induces current and flux in the next input coil (3).  This continues around the circle with the magnetic field cork screwing around the circumference of the main collector coil circle.  When the magnetic surge makes it round the circuit, it acts as positive feedback for the first input coil.  I also think this cork-screwing and spinning of the magnetic fields pulls in more radiant energy, which causes the current to keep flowing in the same direction.   If the pulses and resonance were optimized, the tpu would quickly pull in too much voltage and cause catastrophic arcs through the wire insulation or capacitor insulation.  This is why SM tunes the circuit off frequency slightly.  You can also see he has put fuses on the big tpu device.
I do not think the earth's magnetic resonance is critical to the operating of the tpu.  It is a radiant energy device pulling its energy from the vacuum.  I think you can pick different sets of frequencies.  In his first small device, maybe SM thought the earth's vibrating magnetic field played a role, but the later devices vibrated much faster.  By setting up his device to resonate at 7.3 Hz, maybe there was a significant braking effect from the earth's flux that happened when he turned the device upside down.  The magnet on the small device probably just triggered a magnetic switch that turned on the device.  He has said that the magnets are not critical to the operation of the device, correct?  On the larger device where he turns it on by placing two magnets, I think that he purposely underwound those two coils so that they would not produce enough flux to keep the positive feedback building.  The magnets were used to augment the flux of those two coils and allow the turbine effect to build.
Also, I think that high ohm leakage resistors are placed in parallel with each capacitor in the various tank circuits.  On the large tpu it looks like he has resistors across the pair of vertically oriented caps.  These dissipate the voltage on the caps when the device is turned off as a safety measure.  They also serve to bleed some of the current and create some extra ac "hash" on the dc current, which causes additional resonance in the tank circuits.  It also causes the vibration of the device, which also contributes to the flux of adjacent coils inducing more voltage and current much like a guitar pickup picks up the vibration of a metal string.  Maybe all of the coil wire should be ferrous? Has SM said anything about what kind of metal the wire is made of?  This vibration and the current drawn from the device when it is powering a load are what cause the device to heat up.  I imagine having a bank of several units wired in parallel to abate overheating issues.
On the big tpu device the inductive coils in the center might be there because he needed a certain amount of induction for his vertical collector coils, but he did not need all of the coil to be close to the input coils creating the positive magnetic feedback.  It may have been a way of maximizing the LC tank resonance but reducing some of the positive magnetic feedback.
I think the gyroscopic effect comes from the cork-screwing magnetic field that is constantly circling around the circumference of the device.  This also seems to match his statements about the tpu acting as a turbine or an accelerometer.
Please, let me know what you think, everyone (including you, SM).  I have to study a lot more before I can draw up a possible circuit to test.
And if more info is needed then click on the LMDTEM link below. And get the vid of the experiment by Dolllard.
Or study Tesla, Keely, Schaumberger. Try to explain the results of Hutchison to your parents.
But condemning people does not bring peace into our lives.
--giantkiller. Those that can do are always told 'No' by those that can't.
poynt99
DFRO is as lost and subject to regurgitation as much as countless others before him. He has a couple good observations, but nothing new by any stretch.
what sort of "physical evidence" are you talking about?....how I can blow my walls out with a sub-woofer?
as i said this all has nothing to do with the TPU
ramset
Thanks Grandma
