Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
0 Members and 25 Guests are viewing this topic.
mikestocks2006
So then, that's the answer to the TPU energy generation, isn't it?
In principle, a single pulse on the coil will produce a voltage on the antenna wire , and if you place a load on the ends of the wire then a current will flow, but due to the direction of the current flow there can be no BEMF opposing the current flow in the coil. (the induced fields are perpendicular to each other, right? Excluding ohmic resistance for a moment, What goes into the coil, comes out, but now there is the "extra" current and voltage on the "antenna" wire.
So next if the antenna wire is fairly long and the coil is wrapped around it for most of the "antenna wire"  length, is the antenna wire expected to collect higher voltage and allow more current to flow through it when there is a load placed at its ends?
If yes then that's the answer to " free energy" generation, right?
Next step would be to loop that wire (antenna, or collector if you will)  inside a toroid and pulse the toroid, using some of the wire's out put fed back to the toroid to cover ohmic losses etc.
By looping it, there is a great more length of collector wire inside the coil, in a more compact space. Fieldd strength inside the coil would be based on number of toroid turns and pulse type, and total voltage/current output of the wire collector would be based on length(loops) etc
So once the basic ohmic losses are covered by a portion of the output the rest is OU right?
Is this the basic principle of operation?
poynt99
so gk has illustrated the simple  Tx/Rx thing I mentioned earlier in this thread.
is it the answer? no, not as it stands.
is the antenna tuned to the 1/4 wavelength of the coil's resonant frequency, and if so, is this the answer?
maybe gk can answer this
sparks
      Scalar wave produced by antennae meets surrounding coil. ;)
Below is scalar wave in coil meets antennae
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Motorcoach1
after reading and going over some old patents from Stubblefield. In looking at his earth battery and transmission machine, I have come to a conclusion about the antenna system. one thing I believe he left out of the patent is the carbon block set up inside the coil the antenna is connected to or should I say the antenna wire runs down through. the carbon block is set at a distance to an iron block , this could be slightly magnetic. the freq's could be modulated at this point and gain in power would be present. transmision over long distances in a single wire would be the same as a small coil the energy is just confined. so now the capisitor 2,2 uf @350wv would be wound inside of the primary coil(around the cap) and the carbon resistor conected to this would have the slightly magnetic -magnet close to the resistor 1 or 2 ohm. The secondaries would be as stubblfied had them coiled flat and in sequence of the plates , were not useing plates due to the fact that we are not useing an iron core, so the secondaries may be connected to each quardrent of the primary. A 555 chip may work as the timeing device only.Ã,  when we look at SM's first small open coil we see him put a magnet on the unit , This may be that he is setting it close to a carbon wound coil or ferrit this sets up a modulation to the primary coil. This would be close to Stubblefeilds iron and copper found feild coil , wraped parralel on the bobbin.        @ GK I'm fimilir with the AM reciver and crystal radio set ups, but i feel there is no ether to get the current up. the interesting thing is when i am working on the testanika machine and useing quartz cyristals and swapping them out with a uranium base rock. Stefen told me about them as i had already know but I was not at the point of testing them. I'm dealing with a resonate mag feild rather that a direct current feild and converting the eather to useable function. So now how do I amplify the power that I'm getting is the question. This is where I'm useing the capisitors in the coil as switches rather that caps as a rule.
giantkiller
These are a set parameters:
It is also not the frequency but just pulsing and on a dc bias if you want. The idea of having coil configurations like the ionizer patent 568177 is play time is very productive. I have 5 like this, ECD,  GK3, GK4, notched pvc, & BFG(the largest number of ionizers equalling 18 in one unit). The spark gap shows the usable potential in a small platform. It has to be converted from high v / low c to low v / high c. The ionizer coil does this. Like an inverter.
Not more than we put in? The BEMF is quite high in voltage.
How does the quarter wave of the SM17, SM6, SM4 diameter match up with 5khz?
And this little beauty puts out 30kv @ 8A from a 9v battery with no internal spark gap.
--giantkiller.
