Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
sparks
@ Alecks
    Please reread what you just posted.  Because the tpu bounces the energy around just like you said but it bounces it a little further away and into a much larger frame of inertia than our little tpu circuit.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Localjoe
@ All check these phrases out.....
In the present application
my object is to describe the best and
most convenient manner of-which I am at presently aware of carrying out the intention as applied
to a system of electrical distribution;
but one skilled in the art will readily understand
from the description by the modifications
proposed in said applications, wherein the form of both the generator and converter
in the present case may be modified.
381970
The inducing or primary coils wound on the core I
are divided into pairs or sets by the proper
electrical connections, so that while the coils of
one pair or set to co-operate in fixing the magnetic
poles of the core at two given diametrically-opposite points, the coils of the other pair
or set?assuming, for sake of illustration, that
there are but two?tend to fix the poles ninety
degrees from such points. With this induction
device I use an alternating-current generator with coils
or sets of coils to correspond
with those of the converter, and by means of
suitable conductors I connect no in independent
circuits the corresponding coils of the generator
and converter. It results from this that the different electrical phases in the generator
are attended by corresponding magnetic
changes in the converter; or, in other
words, that as the generator-coils revolve the
points of greatest magnetic intensity in the converter will be progressively shifted or
whirled around. This principle I have applied
under variously-modified conditions to
the operation of electromagnetic motors, and
in 'p previous applications, notably in those having Serial Nos. 252,132 and 256,561, I have described
in detail the manner of constructing
and using such motors
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Localjoe
The armature
is set to revolve within an iron shell, R',
which constitutes the field-magnet, or other
element of the motor. This shell is preferably
formed with a slot or opening, r, but it may
be continuous, as shown by the dotted lines,
5 and in this event it is preferably made of steel.
It is also desirable that this shell should be
divided up similarly to the armature and for
similar reasons
381968
Joe
buzz-ard
Look carefully at the winding of the converter in 381970 & 382282 - it's clearly wired as an AC device. But this I do believe to be one basis for SM's device, only wired in a DC configuration and running at higher frequencies. "Listen, you need to make three coils or so, one on top of the other." - SM
My early experimental TPU builds employing this concept and using square-wave input have shown a low-integrity high-frequency DC component, along with the expected sympathetic AC obtained through resonance. It's a matter of tuning the build to generate sufficient DC frequencies to result in the cascade effect that Tesla's device achieves with AC. It's entirely possible that SM's output is actually an AC signal, but with the lower or upper part of the resulting sine missing or shoved into the opposite domain to create something more DC than AC in behavior. SM saw that Tesla's device could be truly useful if the generator were miniaturized, and realized that DC conversion was possible because of the higher frequencies available to today's techies.
You wouldn't believe me if I told you.
Feynman
@localjoe
Just to comment on differences between iron and steel
Iron:
wrought iron has very high magnetic permeability. usually ip=1000 and up.
Steel:
stainless steel is non-magnetic. it has low permeability.  ip=200 and below.
rolled steel is magnetic. it is 98-99.7% iron.  it has similar permeability to iron.  ip=200-1500.
are you talking about stainless steel or rolled steel?
thanks
