Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
innovation_station
@Feynman
you know your steel well i went and got some water pipe  5 and 6 " i think it was a mild steel not too hard to drill or grind it is 1/4" wall  seams to be quite magnetic
im hopeing it works well i have not tryed the steel out yet   {laqueing driveing devices}  just getting some of my older things finished that and of course makeing new things to me any ways ;)
hey i did this little old test a wile ago as did most of us  guess where im going next  yep back to that little old test  ;)
i just finished this little kit i bought it is a lite chaser 4 channel not too fast tho but hey thought i would throw somthing togather out of it and see how well it will work  .....
this is the ist cork screw coil
ist
Localjoe
@Feynman
Those quotes are directly from the tesla patent no's i listed with each quote.
        Joe
@Buzzard
Check out 381968 that has the modifications proposed and confirms that you can wind multiple sets of coils superimposed upon one another. Good find
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
aleks
Quote from: buzz-ard on April 19, 2008, 10:29:59 PM"Listen, you need to make three coils or so, one on top of the other." - SM
SM's open TPU does not have coils "one on top of the other", so this suggestion does not look universal.
aleks
One thing to note. I've read an article dealing with "cold thermonuclear synthesis". There, most experimentation deals with HV pulsing: e.g. titanium plates in water being pulsed with 5kV discharges. Titanium isotope transmutation happens together with pollution of water. Another experiment deals with 100micron wires pulsed by HV. As a result, much OU energy is released, confirmed by precision calorimeter measurements.
So, I guess we are on a right track assuming that pulsing produces OU energy. I just hope someday mainstream science confirms existence of zero-frequency acoustic wave formations. Then again, the guys are talking about 'monopoles' which can in fact be DC acoustic wave formations (monopoles in their theory appear to have field of 100000 T near their center - unbelievable intensity).
To reiterate myself, while these formations have ultra-low energy, they produce grand effect on the strong nuclear forces. Probably they also produce alike grand effect on EM fields "compressing" and shifting their spectrum and thus producing OU energy. I would speculate that while low-energy pulses (those used in TPUs) may affect EM fields only, high-energy pulses (50kJ as in mentioned experiment) may perform transmutation. The latter one is dangerous, so it should not be considered.
(from http://www.uf.narod.ru/pop/Fusion100_Rus.htm)
1. condenser battery 2. discharger 3.inductive wire 4. Ti foil 5. Ti electrode 6. polyethylene cap 7. cap fasteners 8. explosion chamber 9. distilled water
To sum it up again, at first we need to create an "inductive energy cloud" which is achieved by a slow ferromagnetic, PVC, plexiglass, wood, whatever core. Secondly, we should pulse this cloud with short 1ns rise time pulses with high enough energy (several mJoules per pulse). Thirdly, we should have an "energy sink" in a form of a collector wire. Since pulse circuitry "opens" for a very short time to produce a discharge into core, any surplus energy can only flow into collector wire inbetween pulses, especially if pulse circuitry is protected with a diode.
The only important thing that should be regarded is that DC magnetic bias does not produce induction. So, the output should be a biased AC, and pulses should be tuned to produce high-freq AC in the collector wire. If 5kHz is something important, related to some earthly resonances (I'm not sure it is), then pulses should be tuned to produce 5kHz AC output. One note, though, is that you can get DC current from biased AC by applying an RC stage. It's simple: AC will be removed, DC will remain. This mix of data I've provided is very close to mix of information provided by SM himself.
sparks
    The problem with using steel in the core is that it takes time and energy to polarize the steel.  It is frigging slow as molasses.  Move up to a 400hz motor and you will find alot less steel in it than a 60hz motor.  These are motors guys not generators.  How much steel do you think you will need inside a 5000hz motor?
   transmit a hf spike across a matched antennae and feed back the oscillations to the transmitter instead of feeding them to a speaker.   "Of course if the whole thing turns into a bomb...."
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
