Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
0 Members and 28 Guests are viewing this topic.
sparks
     Joe I can see it happening!
   The magnetic domain shifting taking time in the iron wire meanwhile the copper resonance disruption occurs closer to the speed of light.  This way the magnetic energy release of the copper is given direction by the iron magnetic response to the same catalysing pulse.
   Thanks Joe for another lesson. :)
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Localjoe
@sparks
Cool, please read pats no's 381,968 382,279 then 381,970 read carefully to the propsed modifications in the first two patents and there implications, write it down, then read 381,970 and the refrences to the modifications proposed in the two prior patents .. sneeky sneeky.
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
aleks
Quote from: Localjoe on April 20, 2008, 02:08:37 PM
Are you suggesting that Tesla hid some "overunity" clues via patent system? "Information within information"? :) If so, what have you discovered?
giantkiller
Quote from: aleks on April 21, 2008, 12:47:15 AM
high self-induction:
This barrier caused the ?bunching? effect. Electrostatic charges were literally stopped and held for an instant by line resistance, a barrier which only existed during the brief millisecond interval in which the power switch was closed. The sudden force application against this virtual barrier squeezed charge into a density impossible to obtain with ordinary capacitors. It was the brief application of power, the impact of the charge against the resistance barrier, which brought this abnormal electro-densified condition. This is why the conductive wires in his present experiment often exploded.
With both the oscillations and alternations eliminated, new and strange effects began making their appearance. These powerful and penetrating phenomena were never observed when working with high frequency alternations.
The effect was definitely related to time, IMPULSE time. Second, Tesla found that it was imperative that the charging process occurred in a single impulse. No reversal of current was permissible, else the effect would not manifest. In this, Tesla made succinct remarks describing the role of capacity in the spark radiative circuit. He found that the effect was powerfully strengthened by placing a capacitor between the disrupter and the dynamo. While providing a tremendous power to the effect, the dielectric of the capacitor also served to protect the dynamo windings.
The effect could also be greatly intensified to new and more powerful levels by raising the voltage, quickening the switch "make-break" rate, and shortening the actual time of switch closure.
When the impulses were short, abrupt, and precise in their successions, Tesla found that the shocking effect could permeate very large volumes of space with apparently no loss of intensity. He also found that the shocking effect penetrated sizable metal shields and most insulators with ease. Developing a means for controlling the number of impulses per second, as well as the intermittent time intervals between each successive impulse, he began discovering a new realm of effects. Each impulse duration gave its own peculiar effects.
Tesla found that impulse duration alone defined the effect of each succinct spectrum. These effects were completely distinctive, endowed with strange additional qualities never purely experienced in Nature. Trains of impulses, each exceeding 0.1 millisecond duration, produced pain and mechanical pressures. In this radiant field, objects visibly vibrated and even moved as the force field drove them along. Thin wires, exposed to sudden bursts of the radiant field, exploded into vapor. Pain and physical movements ceased when impulses of 100 microseconds or less were produced.
With impulses of 1.0 microsecond duration, strong physiological heat was sensed. Further decreases in impulse duration brought spontaneous illuminations capable of filling rooms and vacuum globes with white light. At these impulse frequencies, Tesla was able to stimulate the appearance of effects, which are normally admixed among the electromagnetic energies inherent in sunlight. Shorter impulses produced cool room penetrating breezes, with an accompanying uplift in mood and awareness. There were no limits in this progression toward impulses of diminished duration. None of these impulse energies could be duplicated through the use of high frequency harmonic alternations. Few could reproduce these effects because so few understood the absolute necessity of observing those parameters set by Tesla. These facts have been elucidated by Eric Dollard, who also successfully obtained the strange and distinct effects claimed by Tesla
He had discovered a new induction law, one where radiant shockwaves actually autointensified when encountering segmented objects. (high self-induction)
Patent 381968, 381970, 390721, again...
There is no current because the electrons do not flow. The high energy is composed of the sheer high speed ;) kinetic energy. The atom rings and sings the universe electric. The energy is transmitted by sheer force faster and harder than the atom can expel matter. We are generating and playing with sub atomic shock waves. :o
In the famous words of Wil Smith in the movie 'Independance day' 'I gotta get me one of these!'. So build one per 381968. I got one and it sits on my desktop. :D I am sure there are a few others out there too.
The power of the universe sits right in front of me.
If the previous example is too complex:
http://www.pat2pdf.org/patents/pat382297.pdf
--giantkiller. Plain and simple.
Localjoe
@aleks
Gk did a great job explaining the effects ThanksÃ,  :-[ .Ã,  Its hard to decipher tesla's shit sometimes but this is as far as i am.Ã,  Between those three patents the first two i mention will let one understand how he operates motors and generatiors on these principals. And modifications that can be made on either to increase efficency and eliminate moving parts.Ã,   In 381,970 he describes how to combine those modifications or their uses in the bigger picture.Ã,  As well gk dicussed one further than ive gotten 390,721, Make sure to check 382 279 it is mentioned in 381970 but only its serial no is mentioned which is confusing. Once i can finish drawing this thing according to how he describes the mods i'll be back. last but not least.. the magnets might have an acctual purpose . Not often you find tesla using permanent magntes as opposed to feild mags.
Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Joe
