Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
sparks
   @Local Joe
   I just want everbody to understand that energy displaces the aether and the Aether has fluid properties. Tesla called it not fluid but "elastic".  Energy displaces it.  When you examine the patents be sure you note which way the fluid is flowing.
  @Armageddon   Particles are just models.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Localjoe
Quote from: sparks on April 23, 2008, 02:35:22 PM
Ã,  Ã, @Local Joe
Ã,  Ã, I just want everbody to understand that energy displaces the aether and the Aether has fluid properties. Tesla called it not fluid but "elastic".Ã,  Energy displaces it.Ã,  When you examine the patents be sure you note which way the fluid is flowing.
Ã,  @ArmageddonÃ,  Ã, Particles are just models.Ã,
@Sparks
I completly agree but without the means to create the energy your speaking of its non sequitor to talk about, once we have a converter built to spec then observing that phenomon might help us to better the device but as armageddon said and i agree you still need the device working and configured properly to produce those "effects" you speak of .Ã,  ;)
Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,   Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Localjoe
From pat 382,280
Again considering the apparatus illustrated
by Fig. 9 as typical of the invention, it is obvious
that since the attractive effect upon the
disk D is greatest when the disk is in its proper
65 relative position to the poles developed in the
ring Rââ,¬â€that,is to say, when its ends or poles
immediately follow those of the ringââ,¬â€the
speed of the motor for all loads within the
normal working limits of the motor will be
practically constant.
It is clearly apparent that the speed can
never exceed the arbitrary limit as determined
by the generator,. and also that within certain
limits, at least, the speed of the motor will be
independent of the strength of the current.
It will now be more readily seen from the
above description how far the requirements of
a practical system of electrical transmission
of power are realized in my invention. I secure,
first, a uniform speed under all loads
within the normal working limits of the motor
without the use of any auxiliary regulator;
second, synchronism .between the motor
and the generator; third, greater efficiency by
the more direct application of the current, no
commutating devices being required on either
the , motor or the generator; fourth, cheapness
and simplicity of mechanical construction;
fifth, the capability of being very easily managed
or controlled, and, sixth, diminution of
danger from injury to persons and apparatus.
These motors may he run in seriesââ,¬â€multiple
arc or multiple seriesââ,¬â€under conditions
well understood by those skilled in the art.
I am aware that it is not new to produce the
rotations of a motor by intermittently shifting
the poles of one of its elements. This has been
done by passing through independent energizing-
coils on one of the elements the current
from a battery or other source of direct
or continuous currents, reversing ,such current
by suitable mechanical appliances, so that
it is directed through the coils in alternately
opposite directions. In such cases, however,
the potential of the energizing - currents remains
the same; their direction only being
changed. According to my invention, however,
I employ true alternating_ currents; and
my invention consists in the discovery of the
mode or method of utilizing such currents.
The difference between the two plans and
the ad vaittages of mine are obvious. By producing
an alternating current each impulse
of which involves a rise and fall of potential
I reproduce in the motor the exact conditions
of the ,generator, and by such currents and the
consequent production of resultant poles the
progression of the poles will be continuous
and not intermittent. In addition to this,the
practical difficulty of interrupting or reversing
a current of any considerable strength is
such that none of the devices at present could
be made to economically or practically effect
the transmission of power by reversing in the
manner described a continuous or direct current.
In so far, then, as the plan of acting upon
one element of the Motor is concerned, my invention
involves the use of an Alternating as
distinguished from a reversed current, or a current
which, while continuous and direct, is
shifted from coil to coil by any form of commutator,
reverser, or interrupter. With regard
to that part of the invention which consists
in acting upon both elements of the motor
simultaneously, .1 regard the use of either al
ternating or reversed currents as within the
scope of the invention, although I do not con-
Bider the use of reversed currents of any practical importance.
What I claim is
The method herein described of electrically
transmitting power, which consists in producing
a continuously-progressive shifting of the
polarities of either or both elements (the arms- to
tore or field magnet or magnets) of a motor by
developing alternating, currents in independent
circuits, including the magnetizing-coils of
either or both elements, as herein set forth.
NIKOLA. TESL A.
PS
Multiple series = series
Multiple arc = parallel
sparks
Edit
      I think Acer compiled a whole bunch of posts by ERfinder all about Tesla and the tpu.
Think Legacy
Spread the Love
giantkiller
Quote from: aleks on April 23, 2008, 12:47:04 PM
Quote from: giantkiller on April 23, 2008, 11:39:43 AM
That is the GK4. Each red coil of 29 gauge is a segment and only one layer. It is wrapped additionally with single trace of multistrand lamp cord by each segment also. So 12) 28awg segments ( high inductance) encompassed by 4) lamp wire segments (low inductance).
Why lamp wire?
Do you have pulse plots of 29 gauge wire segment pulse and iron wire core in parallel?
The talk at the time was lamp wire and many paths. Since I didn't see any real results that I could understand at the time I readily went with what I found at radio shack. This was one of SM's remarks. Other posts were talking about 3 and 4 segments. I saw the Telsa patent 390721 transformer then found the 381282. Lo and behold that transformer was all over the place! So I took ahold of Tesla's design and went with it. After all, It works and at the time the Overunity site was vague.
I can switch the lamp wire out for iron. Aleks and Sparks both mentioned it.
--giantkiller
