Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
giantkiller
aleks
Quote from: Loner on April 28, 2008, 01:25:29 PM
A little historical note:  I have previously mentioned "Core" memory, which will hold the spin
for at least 20 Years, and probably forever.  This has no magnet in it, but operates exactly
as the PMH.
Make sure they are same things before doing any conclusions. PMH stores energy: even an unconnected amperemeter shows current when placed in the field of PMH (as far as I know there are even such things as EM battery exist based on this principle). Can amperemeter show current near permanent magnet? I doubt it, that's why "core memory" and PMH may be completely different devices.
giantkiller
Leedskalnin: 'Little magnets'
Steven Mark: 'Many paths'
Equals 'Flux lines'
Rotating magnetic fields equals circulating magnet polarities. The currents go in 2 directions in the wire. The fluxes are the paths.
Edward also states that fat copper at the end stage gives volumn or a larger conduit.
--giantkiller. Litz not included
aleks
Quote from: Loner on April 29, 2008, 05:20:55 AMThe way to read the core is to charge
it in a known way.  If it changes the core, you get the energy pulse out through the sense
wire, without affecting any other core.  If it doesn't change, then no signal.
Well, OK, so PMH and "core memory" do look like similar things then.
aleks
For your entertainment:
Hi-res: http://web.utah.edu/unews/news_images_2003/May/feng_1.jpg
Silicon atom force microscopy - note a bit of correlation with Keely's "atomic spheres".
(http://web.utah.edu/unews/releases/03/jun/orbitals.html)
A tip of atomic force microscope - pyramid with an eye on top of it could be a misinterpretation of our predecessors when they've "remote viewed" their future.
(http://www.nanowerk.com/spotlight/spotid=4876.php)
