Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
0 Members and 31 Guests are viewing this topic.
giantkiller
@Mac CD,
Tonight I will. I have the 4 bifilar coils on the iron bars. All 1 layer. Like Sparks had suggested. I will monostable pulse the coils all in series first. Ed.L. said 'Just tap the battery to the terminals to start the rotation'.
--giantkiller.
sparks
    @gk
    Timing is everything!   ;)   Tesla's dynamic transformer is cool.  I like his device for wireless power transmission which he developed later on in his career.  I don't believe he used any steel in this invention.  He just pulsed a two turn winding around a pancake secondary winding.   As the magnetic field displacement from the primary kick traveled inward,  it cut across the secondary coil which produced a stronger and stronger "magnetic disruption" as each turn of the secondary copper winding chased the original kick plus the kick produced by the turns outside of it.  By the time you get down to the inner turns the copper there was seeing a pretty hefty change in the ambient magnetic field.
   No rotating magnetic field,  just a compressive magnetic field where he happened to put some copper mass to convert some of it's mass natural resonance into "translatory" energy.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
MACEDONIA CD
HI
AGAIN   @ GK  i like to point  direction  of this
find  how  you  can make  this  you put lets say 2 hz and make  of that 6000 cicluse  that is the ansfer
is not mather  to put  khz   or biger frek  is point how you can make   more  kick  only  whit  very small  in hz  not  push  bider hz   <,i have put  small hz ther  and  i have  more out kick in my  out coil <<like you have  transformator   you put 60 hz  to the prymar  coil  and you have 6000 hz  in the secondary coil  that is that  you  going in that way  whit  small in frek..  max  to  100 hz  not more then this
giantkiller
@Sparks, @Mac CD,
I understand both of you. The steel with the copper coil makes it look like a transformer. And beauty of it is they can be pulled off and replaced just a coil of copper windings. I think there are multiple factors that can be affected here.
I will try all. This should be fun.
Plug and pulse...
--giantkiller.
sparks
  Lots of ways to excite copper and steel and iron at different times to move a dead old magnetic field around   very very quickly.   You be careful GK.  Not much copper at first.  Copper mass (or gold or silver) is the fuel tank.  You might want to get a pidgeon for a pet.  They can feel the magnetic field changing long before shit goes boom. ::)
Think Legacy
Spread the Love
