Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
loosecannon
read in another TPU thread that someone suggested blowing dry ice fumes at the device to "see the vortex".
is this applicable here?
would this help anyone see whats going on in their coils?
am i wasting everyone's time? LOL
just hoping to fire a few synapses out there.
LC
giantkiller
Great test!
QuoteII
MAGNETIC FORCES
7. General?If we do not speak very exactly we may say that the space surrounding a magnet is a magnetic field, but this is not in every case correct. It is correct to say so if the magnet is in the form of a bar or sphere or disc, the bar may be straight or bent; but the more bent it is and the closer its ends are brought together the weaker does the field become, and there is one form of magnet which has no external field at all. (Of the internal field we will not speak here.) That form is the ring. If we imagine the bar with poles; its two ends being bent round into a ring and then welded together, these two poles which, as we know, are of opposite nature, are united and cancel each other out and the ring has no poles. But where there are no poles there can be no external field a matter we will look into more closely immediately. But first of all comes a question closely associated with this : is there under these circumstances any justification for regarding the ring as a magnet at all? It is, so to speak, dead and has no outward effect. This is a point which we can and must answer. Its inner life is all the more active; the inner field is extraordinarily strong and has besides very favourable characteristics which are often, and indeed in the majority of cases, much more important than the. outward effect. In a dynamo, for example, it is the inward field alone that comes into consideration: the external field is quite superfluous. It must in fact be eliminated, in the first place because it represents a dissipation of energy, and in the second place because it would cause harm. Where it presents itself it is called a stray field, and in the early years of electrotechnics these stray fields were considerable and spoilt many valuable watches, the iron parts of which became magnetized, to the grief of their possessors. But this difficulty has now been overcome. The modern dynamo is a perfectly enclosed whole, and there is no longer any need to be afraid of its effect upon one?s watch.
SOME SPECIAL BRANCHES OF THE SUBJECT
necessary limitation in the interests of clearness the significance of Ohm?s law for magnetization is considerably diminished.
Moreover, it becomes clear that the so-called fundamental Ohm?s law of the magnetic circuit has no real scientific significance, and that when it is required to apply it to practical purposes one has to proceed very carefully and be guided by the results of experience. But under these conditions it may be and has been of considerable value.
87. The Ring with an Air Gap
The ideal case of the magnetic circuit is that in which the total flux of induction remains in the magnet. This is case is only completely realized in a ring which is covered with uniform windings. If the windings are more thickly crowded together at one place than at another, or if time cross-section of the ring radually or suddenly FIG. 125. changes between
one part and another, lines of force leak out into the surrounding air. As will be readily understood a quite special case arises when the circuit is broken at some point, corresponding to the case of the spark gap in an electric circuit. A typical case of this sort is the slotted ring. I-lere, as Fig. 125 shows, the lines of force for the most part run parallel with the axis, and those near the axis maintain their
parallelism across the gap ; but the outer ones bend outwards as they approach the end surfaces SO that they escape out of the iron into the surrounding space?a phenomenon which was referred to in Chapter II (page io) as the dispersion of the stream lines.
To continue yesterday's folly:
I stand before those who can and will understand through time the perfect folly of mankind's thinking that he and he alone can make a difference. This is true folly. For one can only conquer the debacles of life through the positive connection with others be they in the present or of the past. He who has sought to work alone will remain alone by any costs through solitude or rejection of others and will not see the joys of success but will continue on a path of addiction to others as a parasite or slave.
No weapon that is formed against me shall prosper. Isaiah 54:17
By compressing the flux in the air gap the north and south are made to compress into the ring creating a monopole. The release of the compression on the air gap allows the ring to return to its natural state as a dipole creating a virtual spark gap, tapping. Do this in a circle, stroking. Not by segments but pulse direction, south to north. Just like Ed.L. said.
I will try the next version of the NT382282 with windings creating 4 quadrants where each ends close to the next. I will go so far as putting air gaps in the iron bars in the middle of the quadrant windings. That also does not show in the patent, but is a very powerful control. This feature would have made the GK4 self detonate! :o The high speed flux would not have been allowed to escape. It harms. ;) Simple to build with very expressive results. There is nothing new under the sun.
--giantkiller. On the doorstep to the future where failure was not an option. 8)
sparks
@GK
       Do you think this is worth pursuing?.  Some folks definitely want to see it before they believe it.  The only problem (besides not blowing up the bulbs) is the same one sm had.  Prooving there are no batteries stashed in the tv.  Gonna have to account for every cubic inch inside the old black and white.  I'm going to have to scrounge some flea markets to find an old crt set.  Damn new fangled PLASMA sets.  I might hang some unexposed xray slides around the little Tesla coil to show a little bit more energy conversion from this machine of  forgotten technology.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
@Sparks,
Whatever it takes to 1.) get results or 2:) keeping it simple for others to finally get on board and do tests.
@all,
So here is some supporting documentation about steps I have taken and about things I have mentioned.
Just in case some think I make this sh!t up or are coming off the wall.
Only a fool would argue with Tesla, Leedskalnin, Russell, Auerbach, Troward, Keely, Shaumberger or Steven Mark.
Do what it says...
Now bend the filaments of graduated lengths in a quarter turn with the shortest span inside the curve and you have something that fits in one of the NT382282 segments but 45 degrees shifted. Or just cut the iron wire looped bundle into 4ths. 8)
--giantkiller. Everything is as plain as day unless you prefer to live in darkness.
giantkiller
It just keeps getting better.
Each coil is air core or a flux channel.
The next step is to cover every visual green area with a full winding of copper then on top of that a full winding of iron in pursuit of NT382282.
I already have achieved ramp up to runaway. The height and depth of the intrapulse oscillations exceeded the pulse height by 5%. Smoked a FET. I am preceeding with a level of control. Each step so far has made attainment by noticable levels. 8)
This is with 555s. The xr2206 is next. The 555s have jitter. I believe this is hindering further wave control. The saturation takes place and large forms are apparent but then squelch down.
Cool running @ 800ma.
Received Owon scope replacement board. Need to swap it in.
--giantkiller. Kickin' ass.
