Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
innovation_station
@ GK     take a bow!!  it over now....   go on and take a bow  ;D
well found a kool vid on youtube thought i would share it
nope not me in this vid  8)
http://www.youtube.com/watch?v=vch5_9T4lo0
tpu related hummm...
ist
sparks
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
I am going to catch the kick. It is at end of the ramp up which is over the supply voltage and which is the start of the runaway condition. Then use it as a pulse on another part of the coil. My idea of a delay is to fire the first coil 'A' to drive the ring in a Clockwise direction. Take that kick 'A' and pulse the preceding coil 'B' which is in the Counterclockwise position and so on to coi 'C' which fires 'A'. So looking down on the ring each coil is driven to produce a Clockwise thrust on the ring while the each coil drives the preceding coil. The thrust is pointed in the Clockwise direction while the coil sequencing is done in the Coounterclockwise direction. Can you see the vortex? Rotational pressure to create accumulative wave structure through heterodyning. Shweet!
The GK-E2Lego-PMH is a plug and play solution to this model.
Follow the trigger arrows and one can readily see how the coil the triggers the previous coil to get a flux pulse pushed up behind itself. Cannon balls. The kicker wave ends up in the center of the ring successively forming a swirling Rodin type Moire pattern. Even more heterodyning. No wonder the thing runs away. It scares itself to death. :D
--giantkiller. My best birthday yet is on Sunday.
sparks
@ GK
    So  in this configuration  where would you be able to extract translatory energy that it can be used for doing work?
Think Legacy
Spread the Love
giantkiller
The starting point for this model was to get the runaway. Now I am going produce runaway on 1 coil to set the triggering in sequence. It is just a matter of running wires.
I did 1 coil before but didn't see this extended configuration before. The whole ring has to sequence trigger. Each coil cannot produce power but the whole does it in sequential cohesive timing. The ramp up is the starting point. All the builders that blew fets before are so close. I thought is was a problem. :D It was a blessing in disguise.
I go to wire this up fully. I fixed my digital scope. Got 2 channels back. And Otto's suggestion of just laying the probe on the side of the circuit is pure genuis. Of course, he learned the hard way too.
Up to this point I have squarewaves and made a step forward.
Future configurations are sinewaves, 50hz, steel instead of iron (the last stage of a stun gun is wrapped steel), multiple ring layers. I am thinking of keeping the ramp-up at or below the VCC level. This would do well in a stacked layer. Mobiused before like the GK4 but this with magnetic fields and induction instead of all the layers connected by wire. I have enough  spooled coils to use a readers. Probably any rat shack spool will do from what I've seen. ;D
--giantkiller. I wonder if this time will it be safer? :o
