Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
giantkiller
http://www.altenergy-pro.com/rec.htm
Copied the pertainent here:
Resonance Energy Concept . . .
This Ambient Resonate Magnetic Flux Energy is ever where present, through out our universe.  A human is as a speck of dust compared to the earth, likewise, our Solar System is as a speck of dust in the Galaxy, and in turn, it is a speck of dust in the Universe.  One common denominator in all of these is Ambient Magnetic Resonance Energy.  When disturbed its potential to produce useful energy is present.
Present everywhere, this  Magnetic Flux Energy is accessed by Transformers , ether directly as is the case of Solar Cells or directly by mechanical means.  Resonate Magnetic Flux Fields & Waves (Faraday's action at a distance) allows Energy activation transfer to remote points of usage. Active energy at point "A" translates into energy at point "B." Capture and use of this Free Energy (which exists freely) is at the core of what power companies charge customers. Direct access (bypassing the power company) is far more desirable and efficient, as in the case of Solar Cells. However, solar cell technology requires many active cells to produce energy to power a house. They will still depend on the sun. The Resonance Energy Concept depends on nothing more than the Earth's Ambient background , and a Resonance Energy Device which produces ample energy.
Please do not mistake this for a "perpetual motion" device. It is nothing of the sort. Pull the plug and the power shuts off; necessary parts may wear out over time. The useful energy exists and may be harnessed for as long as the Ambient Background is disturbed, which occurs easily and requires no physical motion on the part of the device. A casual observer watching one of these devices will see only the end result, lights come on, refrigerators run, etc? Without specialized instrumentation it is impossible to see that resonate magnetic  flux is occurring.  However, with Gauss Meters we can see the results of magnetic resonance.
Gravity relates to magnetic resonance flux. Incoming magnetic fields and waves spin electrons producing useful electrical energy. Absorbed fields and wave energy produces heat, thus earth has a hot interior. Physical movement in electrical systems occurs in the direction of current flow, and frictional drag from this inflow current defines gravity. Accretion masses (energy sinks) provide all solid objects with their respective gravitational fields.
There are four major sources providing enormous amounts of ambient background resonant field and wave energy: Cosmic, Galactic, Solar, and the Earth's own ambient magnetic background. It is the earth's electromagnetic background which concerns our purposes, a free, self renewable and environmentally benign source of power.
The earth's electromagnetic ambient background comes from radiation, reflection, deflection, and absorption as result of Faraday's action at a distance.  Special Interest Physics holds the Earth's ambient background is too small to be of little interest. From consideration of the evidence herein to follow we will change Your interest level. Information on the Earth's Magnetic Flux field is available to the public from the US Geological Survey Office in Colorado, USA. When examined and properly understood these maps yield important information regarding radiation reflection, deflection, and absorption of incoming resonate magnetic flux fields through Faraday?s action at a distance.
When properly understood, these maps yield an ambient resonate magnetic flux of 7.2 billion Volts at a point of measure. This is the part of the Earth's Energy System that relates to the Bird on a High Voltage Line. This is the Motor System that spins / rotates the Earth by resonate magnetic flux radiating from electrons which provides the energy required to rotate the Earth. This is derived thus: Earth's mass in Kg = 5.9 X 10 to the 24th power (according to "Physics for Scientists and Engineers", 2nd edition, edited by Raymond A. Serway). Using this information we can calculate the Watts of Electricity required. Absorbed flux energy heats objects from the inside out, thus the Earth's hot interior. Water is strongly diamagnetic - ocean waves present on windless days provide visible proof of the overhead incoming magnetic flux. The earth's weight and rate of spin allow for the calculation of the incoming ambient background energy required to rotate this planet.
Astrophysicist are primarily concerned with light in the visible spectrum rather than magnetic phenomenon associated with action at a distance. While solar energy can translate into electrical power, the spectrum of visible light is only a tiny portion of total resonate magnetic energy spectrum, and can therefore only translate comparatively into a tiny amount of energy. The Solar System, however, is alive with energy from the entire magnetic spectrum, and that energy is far greater than the light produced by our sun. Very high frequencies allow radio telescopes to photograph the entire Galaxy. The following is a radio photograph taken at 408 MHz, that is, all the energy visible in the photograph resonates magnetic flux at 408 MHz, far beyond the spectrum of visible light. (Photo courtesy of Radio Sky, Haslam 408 MHz; www.tuc.nrao.edu  ) .
Our Milky Way Galaxy measures 150 light years, end to end. Red and Yellow indicate the actual galactic boundaries, outer radiated energy is displayed in green. Not visible in this photograph, the Earth exists near the left end of the central high energy area, surrounded by a soup of energy that extends in all directions.
Accretion and formation of Galaxies, Suns and Planets are the result of Energy Sinks. Mass retains heat and is "cooked" from the inside out by the Microwave Background provided by the Universe. Flux moving into Energy Sinks provides the frictional force known as Gravity. Spinning mass in the presence of incoming flux amplifies the gravitational effect.
Previously noted, Solar Energy represents only a very small portion of the total Magnetic Flux Energy present in our solar system and on earth. Solar Devices provide uncomplicated and inexpensive direct access to that limited spectrum of energy. They also open the door to directly accessing other, greater energy sources. All electromagnetic energy harvesting methods include three things: a catalyst, a collector, and a pump. Catalysts include sensitization through doping with certain elements, as well as air and earth grounding. Collectors include temporary storage, as in capacitors, coils, and transformers. The pump ? current system induces movement onward to a point of use. Conventional rotating coils and magnet flux systems activate the electrons present such that action at a distance can occur, serving therefore as an energy activation pump. Indirect acquisition of electrical energy by mechanical means (as in a dynamo - a combination collector and pump) drawing energy from the earth's ambient energy background) is wasteful in its low energy yield and costs to operate, troublesome to maintain, and degrades and pollutes the environment.
Direct access systems (such as solar cells) have the same effect without mechanical action. Magnetic waves, impacting and deflecting, spin local electrons sideways producing useful electrical energy. And while solar energy is inherently limited in its energy yield, accessing the full magnetic resonance spectrum offers an unending, fully renewable, environmentally benign source.
giantkiller
I found this site 2.5 years ago.
There is 1 driver coil. The thin one at the front bottom. The secondary is rung and the other secondaries ring in unison. They are not connected in any way.
He uses capactive trimmers on the external secondaries for fine tuning. Simple and slick.
But this can be done better. Funny thing... There is a small black box there also.
--giantkiller.
bsibille
Get Don Smiths book, a few of his projects are laid out in there ready to build.
Bennyboy
Very interesting site GK, have you tried to replicate any of his 'Proof of concepts"?
starcruiser
Looks like a Tesla transmitter, using a PS of a sort to drive the smaller coil, the other secondaries are tuned to the main unit to receive the transmitted power. interesting potential project though
Regards,
Carl
