Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
0 Members and 396 Guests are viewing this topic.
giantkiller
@sparks,
Yep. http://www.glafreniere.com/sa_electron.htm from the RE_OU_v6.pdf Page 12.
@ all,
Since this thread covers the narrow conduction path of 1 to 1 sharp points(sparks), 1 to many points(streamers), or many to many(heterodyning in space). These things all belong here. 8)
I include this picture as the explanation of the SM17. Remember the 3 loops on the cutaway of the 15"? The middle one is an antenna. Use the top and bottom one in a heterodying process.
--giantkiller.
Grumpy
Quote from: giantkiller on August 26, 2008, 03:02:30 PM
Ok, boys and girls, this is a wake up call!
In all these devices we have an internal field and an external field and one of them is moving faster than the other. Oops, I just had an accident. :D
I have been using the analogy of an "airplane wing" for many moons now - flow over top is faster than flow under bottom - the creates a force perpendicular to the flow (with a wing this is "lift").  I.E.  the aether moves across the wires working it's magic as virtual charges moving at an enormous velocity.  As was pointed out earlier in the TPU Test Results thread - it is the moving charge that induces - not the magnetic field - and doing without mass restrictions is the way to go.
(Oh, and the iron delay is SM's - not mine.)
        -Frank Edwards
Grumpy
        -Frank Edwards
sparks
    I am convinced that all mass structuring emits "radioactivity" all the time.  Mass being nothing more than a mix of vibrations between two primal forces of radiation and concentration.  One force at rest while the other is at work.  Partners in creation!   Planck's work with blackbody radiation tells us that there is a definded em radiation depending on the heat content of a given spacial dimension..  So each atom is continously producing radioactivity at a frequency dependent on it's heat density or temperature K.  As are we.  We run at about 300k and emit far infrared em.  Cosmic background radiation 3k in the microwave band.  The sun 1500k mostly in the visible light band.  The radiation pattern or wave synthesis in the atomic structuring of an element is unique and mostly self-replicating.  The far reaches of the atom or interface plane or valence shell is where things start to get messy.  This is where the frequency between expansion and contraction creates a bumpy nodal plane whose dimension is constantly in a state of flux.  This state of flux can be represented by a unique electromagnetic wave emission pattern.
Alignment of the individual atomic nodal shells results in the magnification of the radioactive field surrounding the individual atoms.  By the same mechanism molecular bonding arising from the relative packing of the atomic nodal shells can be disrupted with a resultant dual signature emwave emission from the parent atoms.   Really no need to ionize the atom or split or fuse it.  Just jiggle it a bit.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
@sparks,
Radiant Energy and OverUnity Page 12
2.6 Levels of transformation
OU is Transformation. If a magnetic flux is switched ON and OFF in any system with a MINOR force, you have
OU. The same happens with a static charge (ref Thestatika). The MEG is an example of a MagnetoTransistor,
requiring a perfect tuning, but with the disadvantage of loosing it at loading. The solution is to have a resonant
MEG with transverter diode plug and capacitor discharge system. Pulse length as to permit discharging the
accumulated Radiant Energy component in a totally non-reflecting way to the source.
Understanding the mechanics of how the power is transferred from the AMBIENT into the device, becomes
more analytically tangible as some BOOK rules can be applied to justify that TRANSFORMATION. In ZPE we
deal with variables interlaced with other variables, we start with 3 electric ones that subdivide into 3 more each
and so on to 48+1 levels of basic inter-related LAWS starting from basic Ohms law. Academia knowledge just
needs to be "restructured" as to define aether density and other yet to be known forces related to energy
transformation. OU is not magic, is the magic of transformation itself!
The energy is transferred from Thermal-magnetic regions. If FORCED more then it is transferred from
ELECTRON spin, electron DECAYS becomes VITRON emitting photon (be careful with the BLUE odic flame
= vitrons). Avoid contact; as anomaly fields are created like with the ?USS Eldridge?, where time is beginning to
be distorted (transfers energy from time space tensor, degausses zone, as the Famous Philadelphia experiment
did). Energy transfer becomes awesome force.
If increased furthermore, the HELRAISER effect takes place, where reality is degaussed. Morphogenetic field is
disrupted matter (becomes ideo-plastic) and is turned to primal mind responsive paste. Aether transform occurs.
Nuclear elements can go critical with awesome force, silicon becomes Nuclear Photonic Explosive. The
Helraiser Field creates whatever your mind projects to it. Search info on Montauk project destruction, it was
achieved running amplitrons in looped phase mode, as full 4d state was attained a T-rex monster was projected
from the ID to destroy the base. RV is the BASE for ACTUAL secret government T.A.S.M.I.N project (time
travel).
ADVICE: stay thermal & low power with these devices. Use as R&D tool, use as energy saver device 90%+ idle
energy savings minimal in intermittent use, like grinders, pumps, drills whatever needs to be constantly running
but with intermittent loading (conveyors, lawnmowers & others).
On the Stochastic thermal transform that has been the issue all this time, atoms gravity flow is a type of energy
transformation were the gravity flux is transformed to MAGNETIC electron spin force within the atom. Thermal
energy plays a big part here also. Its energy is transferred to electrical realm.
And as I have stated before, the art of tapping OU energy is the art of transformation. For dominating that art you
have to dominate the current art to its top perfection 98%EFF and UP. Once you have reached the limit, then the
art of extracting the energy from the ambient "DIPOLE" can be attained.
2.7 Electron Spin
The internal structure of an electron consists of 4 Vitrons shaped like 3D 4 faces pyramid. One of them can shift
to a photon, and the electron lowers orbit-releasing energy (pro-photon).
If we look at real matter, all of it consists of ?spherical standing waves?. In Einstein-Bose condensate experiment
when atoms are cooled to absolute 0, they appear like a condensed wave SOLITON (?flattened sphere?). This
creates WAVE pattern interference.
The Electron Spin frequency is 1.6 MHz. Thermal stochastic transfer works in this region quite well. The coil
cools and RF signal self sustains - 2 vitrons one pro-photon spinning within a spherical standing wave. Its
frequency is within the range of 1.5 to 1.8 MHz. It is perceived as background noise in multiple octaves, like
transformer random resonance recording, and LASER Ruby rod resonance.
Radiant Energy and OverUnity Page 13
Electrons are transformers; as they need energy to self sustain they acquire energy, as this energy is transferred
to spherical standing wave strings they create gravity, M field and E field. Alter any, you alter the nature of the
electron "even transform it ". Phi is the only ratio in which waves can "add" and "multiply", expanding or
compressing, non-destructively and infinitly... tranform of circle to straight line and back again... a spiral in 3d.
--giantkiller. Thanks.
