Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
Grumpy
One should not place a great deal of faith in that document. (Radiant Energy and OverUnity - Dan Combine)
        -Frank Edwards
sparks
   I'm going to build the below circuit.    Like GK says copper is fast so the secondary tap windings are going to need some iron to slow things down.  Don't want to messup the primary tank inductance though.  Each wave created by the primary inductor core saturation needs to be absorbed and not reflected.
  @ Grumpy
   I see the electron alot like this Dan Combine person.  Who knows?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
@sparks,
In regards to the primary_tank.gif you posted:
My BFG has 9 of these in it. The current set of the bifilar tests are the precursor to driving the BFG.
And why would I build such a complex piece before testing? Tesla has done all the homework.  ;)
You can build and test in any order with his work. Using resonance as the primary tool over current of voltage. 8)
--giantkiller.
sparks
     Tesla did it all long time ago.  This gif circuit is for us beginner builders. ;)  You can see clearly here that the advantage to this circuit is that your iron delay element (perhaps aluminum with it's paramagnetic signature) is not in the same field as your primary squeeze coil.  Two waves (ed gray's splitting the positives?) in the copper are produced for every kick distributed around the solenoid.  On "normal" induction transformers one winding is squeezing the iron into compliance while the other experiences both dielectric coupling and magnetic field response.  The current draw of the secondary variably saturates the iron and direct inductive coupling of the primary and secondary insue depending on turn ratio's.  Positively a mess.  Same deal in an alternator.  The current being drawn effecting the iron being used to transform the magnetically pulsed copper coils.  These are leftovers of Edison's dynamo years.  Sold a bunch of coal wood oil and methane gas though.  Turned the planet into an infrared oven.  Co2 is black duh!  Time for a class action suit against the power brokers for destruction of the human habitat?  Make them build infrared energy collectors and start precipitating CO2 and putting that shit back in the ground where it belongs.  Sorry just dreaming.
Think Legacy
Spread the Love
giantkiller
LOL.
QuoteThe point is that RE can be created in LOW voltage Hi Q modes of resonance using off the shelve components
and hardware and that OU states can be obtained in standard generators, motors and transformers.
Review the resonance theory (remember the statements we seek what engineers try to avoid - resonance &
natural harmonics) and that we have to turn things ON by turning them OFF short to saturate open to release the
potential into a logarithmic resonant charge into a specific capacitor value. The RV demonstrated that since the
beginning using reverse induction. It surpasses MEG by order of 5 in hyperwave modes. This taken to PM
generators RV / EMA /Muller combination is the key to REA: world ZPE applications.
Charge & Farads determine Joules second, so there is no crap way of determining JOULES - HP transfer in
potential (that finishes off with the debunker crap ) and buries it into a pure DC - volt ampere potential where
power factor issues are also terminated.
Don't push thermal range we see as hot energy but push the potential at the rate of highest impedance Q, nuclear level but not endo/exo-thermic. 12 volts has always made the copper sing.
--giantkiller.
