Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
giantkiller
So the field baraging an existing field. The TPU winds in the Hubbard coil thread is another way to achieve this. But the pancake only uses one pulse against itself. On a ring the TPU would achieve this also.
--giantkiller.
giantkiller
Resonating one coil of a bifilar coil while applying a DC field to the other affords the environment for RE.
The M field is the C and the coil L. This gives a virtual tank circuit and we can ring this for a return.
--giantkiller.
sparks
   Typically we input a rf signal into a tank circuit where the vibrational energy is alternately expressed as an expansion at L and condensation at C.  (aptly named the condensor).   If L is an antennae then we broadcast the alternating expansion and collapse of the ambient electromagnetic field about L.  This could be thought of as a compressed field inside the capacitor expanding  at L and mother nature imploding the expanded field back into the capacitor.
  Tesla in his pat 52140 shows us a different sceanario.   Compression of the ambient electromagnetic field is contained within the compressing element itself.
Unlike the tank circuit where there is an electrical current oscillating back and forth between the compressive and expansive devices,  the voltage differential applied to the terminals of the 52140 results in a one way compression of the emfield in which the mass of the compressive device lies.  This condensation of the energy field is illicited by voltage only with no current involved or regard to ambient magnetic field pressure.  This allows the compression to advance at rates independent of the electromagnetic wave density of the surrounding field or aether.  This is not a typical electromagnetic wave radiation and proceeds with a reverse entropy whereby the resultant state of order is greater than at the beginning of the event.  Time keeps on slipping back to the future. ::)
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
allcanadian
@giantkiller
QuoteIn the 512340 patent the drive is applied from the outside and travels an ever decreasing perimeter while dragging a magnetic field behind it. This field eclipses its own trail behind it and the future path in front of it while traveling towards the center.
When the signal reaches the center then it is routed back outside and run inside again running within its own field again. Two phases of magnetic wiping against a conductor. Just like the devices previously mentioned. But the second time through there is previous energy to bolster the whole process.
The pancake acts as a diode, self coupling transformer, capacitor. The vectors definately get twisted around.
I think it's important to understand how Tesla used this coil, Tesla would wind a heavy single turn primary around the "outside" of the coil in patent 512340. From what we know of the properties of induction this would seem to make little sense as we usually require a large number of turns on the primary and even more in the secondaries to insure efficient coupling between the two. So why a heavy single turn primary? and how could a single turn primary inductively couple to anything efficiently?
I found my answer when I built and tested many of these coils, a man named Karl Shappeller once stated--"we can only utilize what was already present and available for use", in this case we have copper coils and nothing more and this is all we can see----but there is more too this than meets the eye. If you build this coil you will understand there is only one quality of current which will produce results and that is a high potential discharge from a capacitor having a very small capacitance. This quality of current has the ability to "radiate" its energy because of the high potential and high rate of change or short wave period. As energy is radiated we could consider this radiation from the primary as a negative discharge, a negative discharge will expel both positive charge and a negative discharge. This radiation will act outward compressing positive charge(any current in the secondaries), it will act outward expelling and compressing radiation external to the primaries(EM, magnetism). An expansion must compress, a compression must expand, as grumpy has stated we are dealing with fields and these fields have the ability to apply force but what is the nature of these fields and what is the direction of force?.We should also consider the fact that in the primary the current may change direction, alternate, but the high potential will always compress thus irregardless of which direction the current moves in the primary energy will be radiated outward. I think it's also important to consider the fields already present external to the coils as well as the fields supposedly generated, we can only utilize what was already present and available for use, but what is present in the space surrounding the conductors? and how could we utilize whatever may be present to our advantage?
giantkiller
Keely's water hammer is the same model as the ringing a coil in resonance.
Matter flows for a very short period of time. The collision of the 2 parties that stops the flow allows not the matter, but the force to be transfered. Then we grab the force in a secondary unit.
Secondly, if a line of flux can move an electron then the electron can be moved in a path. I say this in respect to the Hubbard & Coler, circular transformers. But operated with resonance we incur kinetic behavior and that can transfer energy.
--giantkiller.
