Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
giantkiller
This comment from http://www.overunity.com/index.php/topic,5417.msg122224.html#msg122224
QuoteOutput is a direct function of Copper mass in rotation along the tempic field. Since the tempic field effects density and gravity as well, this spherical device will emulate a single copper atom along the torsion field, and a single coherent magnet along the Electron shell when Electrons are flowing.
And I piece that with
QuoteProton: [Source of Gravity [inflow of Aether] and Positive Electric Potiental]
Gravaton pair:
Gravaton spiral entry to our density CW    [contracting force] ( as viewed from here)
AntiGravaton entry to our density CW  [expanding force]
The two particles spin around one another as they emerge and regress across our density threshold.
When this particle moves in a tight atomic radius curved path it produces strong forces of gravity due to its helix being sharply curved. Allowing Gravatons to spend more time in our density.
While setting still or moving straight it would be expected to have a positive electrical charge. Its inverse distance from [source] is positive voltage and should be expected to operate all the way across the [DS factor] found in our density.
Electron:  [Source of Antigravity [outflow of Aether] and Negative Electric Potiential]
Gravaton pair:
AntiGravaton entry to our density CCW   [expanding force] (as viewed from here)
Gravaton spiral entry to our density CCW   [contracting force]
When this particle moves in a tight curved orbit at atomic radius it produces strong forces of AntiGravity due to its helix being tightly curved. Allowing AntiGravatons to spend more time within our density. While setting still or moving relativly straight it is the "electric" electron we are familiar with having voltage potiental as its distance from center, which will operate all the way across the [DS factor] found in our density.  Electrons orbiting an atom are aproaching lightspeeds .999 999 999 95 * c. This is very near [source] from our point of view, thus they may have incredible power to tap ZPE if their motions are correctly minuplulated. The AntiGravity filed they radiate is very powerful with atomic sized curves yet weaker overall then the protons.
And match it with this
and connect in these items:
http://www.overunity.com/index.php/topic,4297.msg126789.html#msg126789
--giantkiller. The high speed spinning magnetic field.
giantkiller
The matching up of foulness is quickening.
The woman rides the beast. Revelation, chapter 17
The Greek Euro.
--giantkiller. Belief is a choice. Ignorance is finality.
sparks
   I like the two pancakes with a rotator in between.  If that doesn't spin up a magnetic field nothing will.  I think the core of this machine will develop alot of voltage relative to ground.  I would caution that you make damn sure there is no way this configuration gets pulsed on frequency or any resultant harmonic.
I believe Cliff Hazelton got something like this going and totally vaporized a copper conductor between the torroid and ground.  He purportedly never could ever find where the shunt to ground went.  Spherics and SM also cautioned on frequency pulsing.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
Rat race ckt up and running. Signals make it to fet driver. Next step is connecting in fets and coils. Lack of time and I want it perfect. Right?
@Sparks,
That is what I am aiming for. After all, the pancakes would be inductively coupled capacitors. We have definately heard this before.
--giantkiller. Whoa there, Trigger. It will spin fast enough!
p.s. I have not lost sight of my goal.
giantkiller
10/01/08 - The Strange Inventions of Pier L. Ighina
The world of Pier Luigi Ighina is of a science never before propagated, in which reality and mysticism seem to join in a way that is both charming and unnerving. As a student of magnetic fields, Ighina developed a great number of inventions throughout his life based on atomic vibrations. He also worked with the interaction of fields between the earth and sun, harnessing this energy to regenerate diseased cells. Ighina’s numerous inventions include a bed of passive resonance, an earthquake neutralizer, and a strange device he dubbed “Elios,” which is said to purify any food matter that comes within its small field of action. But perhaps none of these strange inventions brought as much pleasure to Ighina as the magnetic stroboscope. He was delighted in its capacity to surprise and amaze curious onlookers on cloudy days. In 1998, internationally renowned journalist Maurizio Costanzo went to interview Ighina and witnessed a strange propeller spinning above his humble dwelling in Imola, Italy. Costanzo describes how a hole in the clouds steadily opened and grew as the minutes passed. Later, Ighina admitted that the most satisfying component of his unusual invention was the innocent smiles of children as they watched the clouds retire, as if by magic. The magnetic stroboscopeâ€"which can be compared to Wilhelm Reich’s Cloudbusterâ€"could certainly deliver a magnificent performance. And yet the landmark of Ighina’s work would have to be his discovery of something never before considered by scienceâ€"a small, elusive, yet fundamental particle he named “the atomic magnet.” Ighina devised a mechanism that isolated each atom, consisting of walls of different atoms with decreasing rates of light absorption. It was during these investigations (for which he employed a microscope of his own design capable of magnification of up to 1.6 billion times) that Ighina discovered the magnetic atomâ€"an extremely energetic particle present in all organic matter. After years of arduous lab work, Ighina discovered the most profound nature of matterâ€"that atoms do not oscillate but vibrate. This revelation led to one of his more curious and brilliant inventionsâ€"the magnetic field oscillator. The scientist discovered that if he managed to change the vibratory state of a group of particles, the material itself could transform. What followed was a series of fantastic experiments in which the field oscillator played a leading role. On one occasion, Ighina set up his apparatus before an apricot tree. He then altered the atomic vibration so that it gradually became the same as that of an apple tree. (He had previously studied the indices of this vibration.) After 16 days, he ascertained that the apricots had mutated, almost completely, into apples. Through studying the corresponding vibration of the healthy bone of a rabbit, he excited the atoms of another rabbit’s fractured feet until they were healed in record time. In this way, Ighina understood that sick cells (including cancerous ones) of any individual were possible to cure through a simple, gradual alternation in their vibrational index, if this was correctly calculated. - http://en.epochtimes.com/n2/science-technology/ighina-marconi-reich-cloudbuster-maurizio-costanzo-magnetic-field-oscillator-4905.html
