Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
giantkiller
Wrap a coil, any coil!, shoot it with a stungun in series with a cap, any cap!,
You have a filter which will only self-resonate with the harmonic that matches the Q of the coil and the resonance of the tank, the Q and the LC resonance parameters should match. The broadband transmission will supply the harmonic of the Q.
Hubbard has eight sparkgaps! In sequence and High speed! Rotating by firing circumferencially around a center receptor coil. The gap between his outer and center coils parallels with the offest of the saturable coils in the SM17 center.
The SM17 has harmonics hitting precessionally around the outer ring. The center toriod windings act like Hubbards center coil for feedback purposes.
The split rings of the Lakhovsky device act as multiple tuning forks of different notes. He produces chords and Keely's trichords.
The Leedskalnin bottles in the coils act the same as Keely's tanks. The two bottle trays on the generator act as note generating whistles, but very, very high. There are two like on the door. He blows the bottle whistle on the axial based triangle rock in the same manner as John Hutchison moves the transducer around the target objects between the 2 tesla coils (broadband transmitters).
My Youtube of the Leedskalnin generator is incorrect. The generator is spun counterclockwise. Ed show this with his right hand. He has never lied. The magnetic blades also furnished an air supply across the bottles. 8)
Have an nice day gentlemen...
--giantkiller. I am on the precipice of graduation.
ramset
GK
Gonna get a stun gun and experiment [safely]
You shouldn't have ""all"" the fun
Thanks
Chet
Thanks Grandma
Bob Smith
@ GK:  Do you think your stun gun-cap-coil idea would work with a flash circuit from a camera in series with a cap, then a coil?
Bob
giantkiller
Quote from: Bob Smith on April 03, 2009, 09:55:41 PM
Bob
Charge pump...
Thaelin
   Dont force them, let them resonate at the natural level. If you have the right values
your Q will be your gain factor. That from a 1959 airforce training manual.
thay
