Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
hughl651
Hello Gk
  I''ve been reading your posts and I think you are going to be successful in this endever.
   Here's what and where I am at the pressent time.
TPU data
This is the first day that I have recorded anything about my version of Steven Mark’s Toroidal Power Unit.
I have a collector coil consisting of 21 turns of # 12 solid house wiring wire. It has an inside diameter of 4.25 inches. Over this are wound three coils of the same type of wire, each covering 120 degrees, and each the same length of wire.
  I’m powering this with an old 12v battery that has been used for a couple of years on other experiments concerning resonant transformers.
I’m getting my control signals from an NRI robotics course experimenters set which has a function generator built in . However I’m going to have to build three oscillators to resonate with as my TPU resonates at about 1.2 megahertz, and the function generator only reaches 120 kilohertz.
  I’ve got one on the set made from a hex inverter that covers 1.33 to 2.5 Mhz, as indicated using a Velleman digital scope
  I'll post more later, and would consideer any response as helpful.
hugh
MACEDONIA CD
giantkiller
Quote from: hughl651 on April 05, 2009, 11:03:44 AM
Hello Gk
TPU data
The #12awg does not afford sufficient surface area as stranded. Try the controls without a cap as in no tank. The collapse has to be final on shut off. Or you have to match everything up resonantly. I have done this both ways ways. But you need to see for yourself.
Batteries are good.
--giantkiller.
hughl651
Hello Again
         I'm new  to all thos blogging so please bear with me O.K.
I think I'm attaching a picture of my partial schematic to see if I can doit.
hugh
hughl651
O.K. so that was my oscillator.
       here is the partial schematic.
By the way does anyone have a tube type schematic I could borrow?
                                   Thanks
hugh
