Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
0 Members and 36 Guests are viewing this topic.
giantkiller
If you search on youtube for singerxyz you will see his Rodin dynamic visualizer tool for coils in the list of vids. Just place your coil on an EGA pc monitor that faces up and you can see the patterns. OMG!
I will drag a monitor up from the dungeon into my cave.and use it in the future. Alas, but it is still 2d.
Gentlemen, we are progressing far beyond normality. Now I know how Keely felt.
--giantkiller. I have a cave with a dungeon? Walk this way....
Localjoe
I enjoy my time in the bat cave here..... Music room in basement :)  .... Why do we call it the bat cave.... cause bats use sound man .  Alright enough ranting for myself.
@ GK do you think we could build a rodin way easier  by taking two toroirds having them machine wound the twisting them to a certian degree... I was thinking about it and theres gotta be a better logical way to wind that thing. Any who, if you ever decide to beam up make sure you take your comm badge with you... I sell them at this new site called microrodin.com j/k
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
giantkiller
@LJ,
Yes about the Rodin coil. Wind a standard TPU type coil with 90d couplings, just like the GK4 and Singerxyz's. By heterodyning, one can alter the angle of each mag field. The eclipse angle to the other 2 fields will produce the Rodin / Ratttlesnake pattern. Now, not only will there be that pattern in 2d but the 3d version is what sits around the coil. The 4d is the diamonds of the pattern will appear at differing dimensions and distances from the the generated source. This is all ever changing and dynamic. It will also swirl around the coil in either direction depending on the heterodyned eclispe. I did it with the Bucket-o-vibes and IS did it with his Audiohenge. Thanks, Bolt!
Can everybody see this? It is so damn simple. This magnetic pattern that Russell talked about in the harmonics is the same type patterns that Keely generated.
If you build it, they will come. We are talking about realization of ideas here. You don't need alot of power with the right set of freqs. And the Angels sing out in the heavens.
The start of my second year here in OU is taken me on a phenominal trip! I am breathless...
--giantkiller. Strollin' on the water.
armagdn03
you would have to completely redesign the machine to wind the coil. The patern in rodins coil is actually the same patern he uses to progress from 1 to 2 to 4 to 8 to 7 to 5 etc. to wind it you place these numbers around, and you make each wind in succession, so its not the same as a wound coil with wires seperated. the winding patern is found on the main site, the one with the hand drawing the patern on the circle might as well be us winding the toroid.
I wish I could turn my brain off sometimes, then I could get some sleep.
armagdn03
Quote from: giantkiller on November 29, 2007, 12:56:46 PM
@LJ,
The "rattle snake pattern" does not exist. Rodin actually says right off the bat that the second set of of lines that create the squares arent really there, he just uses them to illustrate a point. notice the colored spirals in the following image, the direction of their spin, this is what is important, the other lines that are counter to this arent really there.
http://www.rodinmath.com/toroid_color.gif
