Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
Grumpy
        -Frank Edwards
acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
innovation_station
@ acerzw
you have done an amazing job all along  ;D
hey maybe i try to wind a peramid next lol :D
ist
giantkiller
--giantkiller. Where do you thing rogue waves come from?
Bruce_TPU
Quote from: Grumpy on December 01, 2007, 10:49:48 PM
...and what if you applied a form of induction that is normally in both directions of a wire to the "one way street"? Like squeezing a hose...with a check valve at one end.
@Grumpy
Would using a simple diode on one end of the wire do that?  If so, you have given me another idea for an experiment to carry out on the MTPU.
Holiday Cheers,
Bruce
