Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
giantkiller
And this is exactly what I am heading for.
I am going to apply combinations like this. The latest coil build will be able to be pulsed in a huge number of combinations. I will always increase the bit precision of the frequencies.
And mods in the future.
I am still winding and am chomping at the bit to get this next one setup and running. I will point it at an EGA monitor screen to see the field patterns.
I can taste the flexibility but many more steps to do.
--giantkiller.
giantkiller
Quote from: Localjoe on December 26, 2007, 04:13:13 PM
@ Tak22 and GK
From the page Tak22 posted
So what's Phi got to do with this?
Phi possesses the strange property of being able to automatically generate its power series when heterodyned successively with its own next-higher or lower powers! I believe this fact is a key to many fascinating areas yet to be discovered. As far as I can tell, this trait is not shared by any other number. Dan Winter seems to be on the right track on this one, for sure.
Powers of Phi
Phi^0 = 1
Phi^1 = 1.6180339
Phi^2 = 2.6180339
Phi^3 = 4.2360672
Phi^4 = 6.8541004
Phi^5 = 11.0901669
... etc...
Now, what do you suppose happens when we take two frequencies, f1 = 1 unit, and f2 = a frequency that is Phi times larger, or f2 = 1.6180339, and modulate them-- nonlinearly mix them-- in an AM modulator? The two new frequencies are the sum, which is 2.6180339-- hey, that's the same as Phi^2, and the difference, which is .6180339-- hey, isn't that Phi to the -1th power? Yup, it is. So we stumble upon the very interesting fact that powers of Phi are automatically generated whenever we "heterodyne" or modulate two frequencies that are related by a ratio equal to Phi.
If we use a slightly more developed form of AM modulator, we can suppress the carrier entirely (and the audio, too) and just get the sum and difference frequencies out. This is what is done in a balanced modulator, and this is called suppressed-carrier double-sideband transmission, just one step away from the single-sideband that Hams and CBers are familiar with.
So here's what we can do: Wire up a string or sequence of balanced modulators; the next one will have the frequencies of Phi^1 and Phi^2 as inputs; the two outputs will be Phi^3 (USB) and Phi^0 (LSB). Feed this into the next one: Phi^2 and Phi^3 will give Phi^4 and Phi^1; etc. Eventually you could generate a very large series of frequencies related by the powers of Phi.
And what if we were to rotate an acoustical field made up of Phi-related tones, or even white noise? Does the vortex/funnel shape, like a logarithmic curve, favor the Phi-ratioed frequencies by its very curvature?
1,2,3,5,8,13,21,34.... how can a bunch of Fibonacci integers give rise to one of the strangest and most prevalent of the irrational numbers, Phi?....
Still more findings... I think theres something there captain ... sensors to full
My wife brings home a dvd. It is called 'The story of the weeping camel'. It is about a distraught mother camel who dejects her new born calf in the Mongolian Gobi desert.
Follow along with me here.
A voilinist hangs his instrustment on the camel's first hump. It is a 2 string violin. How many notes? Its 2 cords, arga (bass) bilig (soprano).
The camel is always griping and bitching with erratic breathing.
Well at certain breaths the voilin resonates. That's right, voilin resonates. This catches the camel's attention. The camel then controls it breathing into harmony with the sounds it hears.
Now the mother lets the calf nurse.
But it gets better.
The breathing changes still more and the camel and violin are one.
The violinist removes the violin, walks back a few paces and plays the instrument.
The mother camel starts pushing the calf into the teet area. Then as the rancher's wife sings and the violinist plays, the camel weeps. For real...
And this happens just a couple of miles north of Tibet.
--giantkiller. Our technology compares not to the laws and knowledge of the ancients.
Localjoe
@GK
Yea it does take ya back to reality.. anyways after looking at Otto's 3 stack drawing and finding out that he made a point about the physical distance between 3 collectors when measure the gaps were .618 and 1.618 phi and Phi i had to mention this again in here .. Now your device is different but in the sense of a BFO that spacing may actually make a huge difference.. just a thought.
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
giantkiller
Quote from: Localjoe on December 27, 2007, 04:01:13 PM
@GK
        Joe
We're going there, bud. The guides that are blue tubes in drawing.
I am going to use vinyl tubes used for Bathroom sink feeds. The coils will be abe to traverse the guides for physical adjustment.
Keely's items could move too.
Any frequency combos, numbers, spans, physical adjustments will be assessed and tried. Consider this like a spreadsheet.
At this time I have all (3) 4 turn collectors wound with 230 turn controllers with 25 turn dual opposing controls on top of those. Finally.
Now I get to multitask down parallel design paths. The controller, the tube, the open config of the coil connections.
One of those little transformers are what is in one the open tpu legs.
--giantkiller.
acerzw
@GK
Nice work, that adjustable setup is the business! Very envious, an amazing range of effects that you will be able to produce with that... will you publish the full specs when your done so others may build it? Seems like the ideal research tool...
Interesting about those transformers too, missed that the first time around...
Did your Russell course arrive? How are you finding it? I am waiting for my copy of the The Universal One to arrive...
I have read some of his work on light, very interesting and I am sure his stuff about the neutral and discharges etc as quoted by armagdn03 is correct. I am however experiencing difficulty in getting my head around how he believes a light spiral is caused by the reflection off of six divisions in a cube. I need to keep re-reading it, as he seems to be referring to two frames of reference and that there is some kind of distortion in our perception of the phenomenon... eek... mind bending... arma if you have a handle on this I would be grateful if you can explain it more clearly...
A
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
