Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
singerxyz
giantkiller
Quote from: singerxyz on January 07, 2008, 10:18:28 PM
Did a google search on  "Walter Russel rhythmic balanced interchange"
http://www.google.com/search?hl=en&safe=off&client=firefox-a&rls=org.mozilla%3Aen-US%3Aofficial&hs=zWP&q=rhythmic+balanced+interchange+russell&btnG=Search
That's a great mantra for OU work:  "Rhythmic Balanced Interchange"
Right on!.
http://www.antigravitytechnology.net/anti_gravity_inventions.html
What do all these guys also have in common? I have to agree with the profoundness of their simple technical solutions to provide profound effects.
Sound... At any level is a force to be reconned with. You either go with it, get pushed out of the way or get obliterated.
I posted that last pic because of the similarity to the notched pvc coil.
--giantkiller.
Localjoe
@Gk
take for instance two disc magnets place one on a screw or something that can rotate and the other above it, parallel in orientation, attracting in nature, but the magnet is fixed on the top eg tape or whatever when you spin the one below it is not in the top magnets grasp yet but as speed accelerates eventually i start to see a sense of inerta/forced circular path .And the magnet along with the screw 9 times outa ten flies upward even tho at a halt in the same position the top magnet has no affect on it or a very small one only enough to stabilize maybe.
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
giantkiller
The rotation of matter seems to show an effect.
With the right rythm of the mixing of electrical and magnetic forces one can use gyroscopic nature to work vertically also.
A spinning force is excluded from the effects impressed on the surrounding matter.
Sine waves would be the only way to get a smooth control. Square waves rock things too hard to get any kind of rythmic control.
These guys used minimal effort to exert a massive change on matter.
So a horizontal high speed spinning magnetic field creates a spherical field surrounding the enclosed item for lift. And the field changes from a toroid to a sphere. Thanks localjoe. I remember you posting that. I think it was you.
Hutchison points the fields in the object direction. At some point he 'gets it right' and the objects move. Just sound. I think the 'getting it right' is the heterodyning at the right location and the right speed in the right rotation. I posted this last year. A spinning field can be attained with heterodyning. A object can be focused on with the spinning field. Looks like the basis for the magnetic drill functionality of the BFG. Just point it at the target mass and use it like a magnetic vaccum cleaner.
So before I stack the 3 layers in the BFG tube I will point them all into a center focus and turn them on. Just like bucket -o- vibes. Somebody suggested I put a glass of salt water in this contraption. I will. I will use sine waves using xr-2206 chips. The 555s need to much to change the wave form. Glad I had other things going on to enable me to back away and think things out better. I can still get square waves if necessary. Also, I am limited in my current time on the bench.
Life is what happens when we are making other plans. John Lennon.
--giantkiller. Thanks to all for the feedback.
sparks
      @giantkiller
   I think of all physical construct of the Universe as the play between two wills.
One trying to concentrate the other trying to disperse.    Einstein's theory of special relativity states that all exists relative to the observer.  The observer is this will to disperse.  It is what guides quonta.  In fact it creates direction itself.  Look at an oscillating electric field.  Why and how does it radiate.  It is this dispersal will.
The oscillating electric field represents a form of concentration of quonta.  The quonta is trapped so to say.  What happens is dispersion will brings itself to bear and the concentration of quonta starts to move.  It's movement all dictated by the magnetic field (flow direction of dispersal will).  Without this flowing energy all would become as one. We move quonta in the form of a copper conductor across a  "magnetic field" (it is actually a faster current) and the dispersion will flows in a vortex which disperses the quonta concentration (the electrons) like a rising water vapor molecule in the eye wall of a hurricane.   Move it the other way and the vortex is formed so as to move the electrons in the opposite direction.
Magnetic poles are just this flowing force in opposite directions.  The interaction of this flowing energy is always to spread out  into a uniform distribution of itself.
I believe the tpu is a construct of man whereby electrons are drawn from a conductor into a vortex flow of energy which gives rise to a sphere of (for loss of another word) magnetic energy.  This magnetic energy construct is very much like the magnetosphere of the Earth.  It is able to channel energy waves not by their electrical properties but by their magnetic properties into the construct.  By accelerating electrons out of their atomic orbitals and causing them to flow in a vortex there leaves a very strong positively charged cylinder.  Positive charge to me is the attraction will at work.    As long as the vortex is maintained so isn't the gravitational field.
     So yes I agree with you on moving rocks with tpus.  Plank one down near a  rock and watch her roll.  Gotta be strong though.  Or wind one around a rock and wait for the moon to roll her around.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
