Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
armagdn03
I wish I could turn my brain off sometimes, then I could get some sleep.
weri812
Hello all
  I see GK   figuared out how to make a light sabor  ;D  ;D  ;D  ;D
looks GREAT
keep on trucking
wer
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
sparks
   A good friend of mine made an em lazer back in the 80's.  He set up a lattice type series of wave relectors.  Each time the wave was reflected it would pickup energy from standing waves inside it's travel field.  Quite a bit of gain.  Use to "fire" it at a flurescent bulb that would most of the time light up and sometimes blow up. :o
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
I will attempt to roll up my sleeves and pull rabbits out of a hat.  The rabbit part is easy :D
So here we go,
If we look at all the SM TPUs we find a common denominator and that is the feedback windings.
Fat copper, low winding count.
This is the output stage wrapped back around either all or part of the unit. Can we say feedback and flyback?
Why PHAT(Potentially Hot and Terminal) copper? Because of the output power at the final stage.
Low winding count equals current.
Now feed that to the control coil arrangement whether part of that or in parallel around the collector. Yes! 90 degrees coupling works. Otto and I showed this last year. And Viola! We have the trigger.
In the SM4 and SM6 models we have the PHAT feedback encompassing the whole unit.
In the SM15 & 17 and the horseshoe model we have the feedback wrapped around voice coils in the center. Marco posted the dancing magnets and the columnar dancing voice coil at this time.
The open TPUs have their feedback wrapped around a portion of the frame in parallel space not with the windings. Why? These fields are picked up by the monitor transformers mounted inside. Sauron posted the picks of these at the time.
Why did SM swipe the magnet? It only worked on the open units. It enables the control and collector fields while enhancing the feedback field. Lets call it boosting to get the feedback field through space to the control coil. Boom. There is the circular function.
Now lets talk about the collectors. They are in the middle of the magnetic field. Push the earth at the right speed and it pushes back. We have seen many, many examples of this in real life. This coil fires against the feedback. And guess what?  The feedback arrangement using audio works here also.
This is the stun gun coil arrangement. Get rid of the spark output and produce magnetic fields. Either way we have product here. There have been many examples of this in both output arenas.
Lighting a bulb is only an example of Wardenclyffe. The ECD is the same. They are stun gun configurations with a resistive element in the output stage before the energy flys focused off into space. The spark gap is a higher energy, going towards ultraviolet. The light bub is in the lower visible range.
The Bombarding Frequency Generator is an accumulation of all these configurations. Nothing new here.  :o
--giantkiller. What a long strange trip its been.  8)
acerzw
Tesla strikes again.
A (that other guy looks a bit like me, spooky!)
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
