Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
IronHead
I have been pretty deep into some very dangerous discoveries and have been reluctant to post anything until  things have been better worked out.
oops  not sure you were asking me.
I'll be on my way as to not high jack this thread .It just seems to happen to me.
giantkiller
Quote from: IronHead on September 27, 2007, 09:45:22 PM
Thats ok.
Grumpy
Last I heard, Eric Dollard was in the Bay Area (San Francisco Bay) and consulting for electrical utility companies.
He still appears at Tesla symposium type get-to-gethers.
411.com will list an E. T. Dollard in that area, but have not called to see if this is Eric.
@IH - Pm'd new cell concept.
        -Frank Edwards
giantkiller
Following this:http://www.geocities.com/leobodnar/audio_amplifiers.html
I got into the ad826 class A's last night and found the positive side amp goes to rail and same with the negative side to bottom rail. Its like infinite gain on top and bottom. The pot adj has not affect.
I put in sine 600mv and get sine 100mv only on bottom side. +-12v battery supply. I even disconnected the fet totems. Same results. I also had 1uf coupling on the inputs and 1uf on the outputs. No change. I removed them both at end.
I can see no misconnections in the 3 amp ckts.
I might just break down and buy 3 and jump over this design issue.
When this problem is out of the way I see with the audio solution using wave guides under exact digital control I will produce the Keeley liberator. The micro processor to DAC to the xr2206's does just that. He didnt use hardly any volume / amplitutde. His vibratory medium was the plasma or gas. I believe the acoustic laser can be made dangerous with the right transducers like Hutchison used pulse down focused wave guides. If the effect can detonate water then solid matter can be altered also. Just like John Hutchison is doing.
So yes I have to get the amps up and press on with the results of the TPU. But I will be back in parallel force.
I hate these brickwalls that pop up. Solid noise.
--giantkiller.
acerzw
@GK, Is and All
Walls of solid noise... can be removed with resonance too.. as you know and have proven! It took me a while to figure out your guilty secret which even you do not yet know!
GK I strongly suspect that you build a time machine this weekend and go back to 1550BC to try a quick test of your Super-Bombastic Audio TPU by giving a bloke who needs an inconvenient wall demolished a hand...  :o
Oh and I do have documentary evidence! Albeit a drawing of the event by someone who heard it third-hand from a friend of a friend of a blind guy who witnessed it... pretty good evidence by any standard...
See below... Two guys can clearly be seen carrying an Audio TPU, behind a guy who takes all the credit with his silly rams horn (or is that Is pretending to be an innocent bystander).
Acerzw, correcting the errors in biblical history  8) ::)
(Walls of Jericho, naughty GK (and Is?) ! Lucky you didn't leave any equipment behind, otherwise Jesus would have ended up doing a podcast which his followers would have dutifully downloaded onto their water/goat powered Joshua-Bose made iPods!  :P)
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
