Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
giantkiller
So here is the big bomb.
Over ten years ago I saw the David Hamel blueprint of the 3 layers of spinning magnets. I knew the mechanics would present problems and I wanted to produce the same 3 layer spinning effect using strictly magnetic fields. The BFG will do this. The heterodyning will produce very fast or Earth resonant fields. I can control this any way I need to.
The generation sources placed on the horizontal plane will produce heterodyning that spins horizontally. Three frequencies placed one on top of each will heterodyne but I can not see how that field will show up or what it will do. The Hamel steel drum model shot off into space. That was 3 spinning layers.
Now it is quite simple to dispell Hamel's drum. But no one has yet to disregard 3 coils on top of each other. :o
So these next steps will mean very much to me and this community. I am using an aluminum casing eventually. The magnetic field of Hamel's steel drum container still intrigues me. ???
Just the outcome of building the BFG2K8 and seeing it stand up (thanks Acerzw) rocked my thinking.
So I have the tip41b-s in place. Used an XR2206 channel sine wave and drove one secondary coil to 1 mhz of a 2volt DC bias with a 200mv sine on top of that.
The only outcome I was concerned with was getting the waveform and connecting the 3 stages. I need to raise the DC voltage then drive 2 more secondary segments.
The resonant frequency of the secondaries is 36mhz. From this I will compute out the 1/2, 1/3, 1/4, 1/5, 1/6, 1/7, 1/8, or 1/9s combinatorial frequencies if need be.
I have limited time on the bench these days so I will push what I can. But now that things are running I can run tests expediously.
--giantkiller.
acerzw
@GK
It rings bells in my head that Hamel's device as you describe it is very similar to Searl's which also has three sets of magnets/rollers, thought they were arranged inside of each other rather than horizontally... so 3 intersecting toroidal fields is definitely significant, either horizontal or vertical. It is also interesting that Searl's device was started with a slight push from the operator and then it became self sustaining and accelerated until the device flew... so free energy and AG in the one device.
Since Searl's device was hand started, it shows a low frequency was enough to begin the effect, which I find incredibly interesting. It is reasonable to suppose that the loss of gravity and the production of extra energy are linked... if we knew how gravity really worked we might be able to explain it... I feel that if I was able to understand Dr Aspdens theories in more detail the link might be found there...  ???
You know when you think about it the Joe Cell has all these properties too... there must be intersecting fields from the cells internal divisions. Also note that the original inventor reported that the device levitated on a number of occasions. So we have three verified accounts of the phenomenon.... you know that is more than is required to invent and publicise and new physics theory in a peer reviewed journal... such as happened with the UnParticle which is the latest gravy train/band wagon of conventional physicists!  8)
I get the impression that most TPU replications up to now, even with three layers have only been actively driving 2 layers, so perhaps the answer is to drive the other layer as well and take the power off somewhere else... but then we already knew that didn't we.  :-\
A (hey, my smileys form half a hyperbolic wave inverted... sad huh, but it could represent Searl's power graph... aaaah)
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
armagdn03
Quote from: giantkiller on February 04, 2008, 11:51:59 AM
--giantkiller.
When you are satisfied with what you have, perhaps you could try
Cutting the secondaries at varied lengths giving them slightly off frequencies to control your secondary beat frequencies produced
Then rewind the primaries so that they are harmonically related to the secondaries (that is their physical stature)
With this you would have almost all parts resonating at their maximum potential, you could crush all who oppose you, or yourself, whichever comes first.
Oh! and here is a cool equation I stumbled onto, (maybe you already have it)
M = 1 / (1 - (Ff / Fn))^2
M= magnification factor
Ff = forced frequency of oscillatory system, or the input fequency
Fn = the natural resonant frequency of the system.
With this you can find out exactly what your magnification will be at different forced frequencies.
Man I wish I could do this for a living, job offers anybody? lol.
I wish I could turn my brain off sometimes, then I could get some sleep.
giantkiller
@Acerzw, yes. There were statements made on the last 2 OU servers last year that verify what you have stated. Over and Over again. And on this OU instance there are numerous links to very dedicated, incredibly intellegant and open-minded people who have proven all the small steps. I but stand on their shoulders and nothing else.
I know my current strides work. I have been gathering up operational blocks to build with. The BFG driven with the xr2206 chips. The xr2206s controlled by DACs from a microprocessor. The microprocessor interfaced with a laptop and a VB interface for frequency control. The xr2206s connected to 3 adc826 audio amplifiers. The input frequencies divided down using Opamps. The adc826 outputs connected to the Bucket -o- Vibes for audio feedback. I need to take the Bucket -o- vibes bottom out for air flow. The xr2206s have PLL capability that I will incorporate for auto-phased control based upon feedback from magnetic sensors around the BFG. A 3d graphic display then will be implemented for visual feedback. Alot of steps and alot of work. But I have started testing during hookups. Both will increase.
Why? A complete control console. Hamel had no control and his devices drew the wrong attention by effecting the belongings of the wrong people. >:(
Kind of answers the use of an aluminum tube instead of a steeel drum, eh...
--giantkiller. I am dead serious.
giantkiller
So here is one test I will do in the beginning on 1 layer.
a slightly different frequency per segment with a slight difference in the DC levels.
I will vary the frequency and the DC levels per segment. Each segment will be fired in a counterclockwise direction.
I will check for air flow and put a testtube of salt water in the middle to see any variances.
@Armagdn03,
I will definately use this info. Thanks.
--giantkiller. Heading towards a vortex.
