Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
0 Members and 23 Guests are viewing this topic.
giantkiller
It is not about oil. Poverty is capital.
How the Money Works: the Destruction of Neighbourhoods
The model works about the same in every country, although the particulars vary between domestic and international agencies and the military and enforcement bureaucracies. Some call it the securitisation process. Some call it corporatisation. Some call it privatisation. Some call it globalisation. What this means in layman's terms is that the management of resources is centralised. This is done through a system of securitisation based on privilege and coercion rather than performance and the rule of law.
From the viewpoint of the neighbourhood there are six ways to centralise local capital:
?         First, you consolidate all retail sales into a few large corporations, including franchise operations, cutting out local small business.
?         Second, you outsource ("privatise") all local government functions to a few large corporations or subject them to such an overwhelming amount of federal regulation that they can be controlled and managed for the benefit of a few large corporations and their investors.
?         Third, you buy up all the land and real estate, or encumber them with mortgages in a way that is as profitable as possible and allows you to get control when you want it.
?         Fourth, you finance the entire process with the profits from narcotics and organised crime that you market into the neighbourhood. This enables you to finance your expansion in a manner that lowers your cost of capital in a way that conveniently lowers the initial price of your investment and/or weakens your competition. I buy your business and land with your money at a fraction of the cost. No one sells her home faster and cheaper than a mother trying to make bail or pay a lawyer to save her family from jail or death. That is why narcotics trafficking is the ultimate form of neighbourhood leveraged buyout.
?         Fifth, you leverage all of this with tax shelters, private tax-exempt bonds, municipal bonds, government guarantees, and government subsidies -- all protected with complex securities arrangements.
?         Sixth, you ensure that the only companies and mutual funds allowed meaningful access to capital are those run by syndicate-approved management teams. To raise significant campaign funds candidates for political office appoint syndicate-approved management teams. Investment syndicates define the boundaries of managed competition that cycle all capital back through their pipelines. That means the only local boys who can make good are those who play ball with the syndicate.
In this way the private equity in a community can be extracted at a near infinite rate of return to investors and a highly negative rate of return to taxpayers.
So once the debt machine has leveraged out your salary against a greater debt accumulation, the gas prices are raised to extract even more of your hard earned little dollars.
A working TPU will take the owner to an early grave.
--giantkiller.
Rosphere
Quote from: giantkiller on March 12, 2008, 05:11:00 PM
How the Money Works: the Destruction of Neighborhoods...
From the viewpoint of the neighborhood there are six ways to centralize local capital...
--giantkiller.
Golly, when you put it that way, the six-ways alternative does sound so much more attractive.  :P
Fight the good fight, lest we cower in darkness...--giantkiller.
Feynman
The LTC6904 chips have arrived
Don't hate on solid state !
giantkiller
I see TEM / LMD in this circuit.
Wonder what the OSC used is?
This circuit ejects energy off at the output stage. Dollard proved this. I replicated this in a gross way.
This works for certain types of applcation while the TPU does not eject it's power. We want the two rings to create a Helmholtz coil with sine waves so the smooth action keeps the field in the rings thereby allowing the most magnetic field action across the tubes. Any wave transmission means power loss. Can anybody say 5khz? Less then 40khz then. But I don't use 7.8hz. Why? Off resonance with Earth. 7.8hz will do this and you get 100% heterodyning with the planet field. Boom!
So we pulse control a resonant circuit in tune with secondary coil tank circuit resonant frequency. And on the next one, and next one. If you have more than 1 segment.
We never saw any complicated windings in the SM17. That was all done in the little box in the center. The cutaway version showed the 2 layers of wires. All connections and control windings were done in the little box in the center. So the oscillator(s) in the little black box pulsed the layers which sent a field from the outer rings back into the little black box in the center. Closed loop, but were not talking wires here.
One could use coils to read the fields coming back to control the VCO. There were coils on top of the little black box in the center. And they were 90 degress coupling input. Been there, done that.
Keep contained or let it fly. Just depends on what the desired output is.
By putting tubes in the coil center we have placed a receptive variable, the heater created ion field. The generated magnetic field will sweep through the tubes innards and concentrate or decentrate the ion field pressure thereby accesing its own control through this feedback mechanism. The anode and cathode will also be affected. Solid state can't respond this way. Anode and cathode but no physical field. Tubes conduct through space. Solid state conducts through substrate layers. Patent 568177 included just for grins. Ion field and no tubes. I have nothing against tubes. I work with them also.
--giantkiller. RFC.
Feynman
I wonder what would happen if you sent in 70,007.8 hz and 70khz into seperate coils. . . difference = 7.8 hz, like binaural beats.
Will my TPU explode??  ;)
