TPU - General Discussion
Started by z_p_e, October 01, 2007, 11:32:43 PM
BEP
Quote from: z_p_e on October 07, 2007, 12:59:34 PM
Water vortexes form because gravity has an effect on water.
Since gravity does not affect a magnetic field, how can gravity come into play in an electromagnetic device?
I'd like to answer that but I've already taken up too much forum space and need to get back to the bench.
For right now I'll just say it is only an opinion based upon past experiences. I mentioned it it the last dancing magnet thread and haven't been able to prove everything drilled into my head. -yet
dutchy1966
This is for whoever still thinks there is NOT a magnetic vortex at play in the TPU:
Here is a phrase from the famous Carl Hurst letter:
17: The imploding television story is very interesting.
Could Mark?s device be close to tapping into or creating such a powerful magnetic vortex?
Has he seen any evidence of magnetic attraction of any objects in or near the toroids?
Do you know the  very clear answer (bold and in capitals!!!) from SM???
here it is.... read it til you never forget again....
and #17: YES
nothing more nothing less......
Leaves only two options:
1. You don't believe SM or
2. There is a magnetic vortex at play.
regards,
Robert
turbo
hi  :)
as my memory serves me right there was also something about drawing a lens when velocity becomes extreme.
some people claim gravity itself is a electric/magnetic force.
i do not know what it is, but i do think it is convertible into another form or forms of energy.
is there anybody getting positive results or am i the only one seeing intresting things?
M.
z_p_e
Quote from: Grumpy on October 06, 2007, 11:08:48 PM
Quote from: duff on October 06, 2007, 01:57:26 PM
2. It may be relevant to convey the importance of the relationship between the resonances/wire lengths of the control/collector coils. I think of it a rotational magnetic reciever. Some of the tests that I have carried on the coils that have visible control windings indicate frequencies in the megahertz range
AND
9. We are Searching for a rotational Kicking field that can be accelerated by applying harmonics.
I believe the first is SM and the second is Mannix.
It would appear from the style, that the entire quote is from Mannix. I know that these quotes are not in the SM material for sure. See Grumpy's original post of the enitre quote here: (Perhaps he remembers where he got it.)
http://www.overunity.com/index.php?topic=1872.msg37186#msg37186
Earl
If the Earth did not rotate, gravity alone would not cause any water vortexes.
Do you understand that your body is NOT being attracted to planet Earth?
Do you understand that your body is being PUSHED to planet Earth by aether flow?
Do you understand that the Moon is NOT orbiting Earth because of mutual attraction balancing centrifugal force?
Can you visualize a thin flat stretched rubber sheet with planet Earth causing a deformation in this surface and in this indented cone the moon is rolling around?  Should the Moon's velocity increase it would rise up towards the rubber surface.  As the Moon's velocity increases further it continues up the cone until it reaches the rubber surface, at which point it no longer orbits the Earth, but flies off into space.  Astronomers call this escape velocity.
THERE IS NO SUCH THING AS GRAVITATIONAL ATTRACTION.
Gravity is only a "symptom" of the flow of aether caused by space-time deformation.  Mass causes space-time to deform.
Electrostatic potential and electrodynamic rotation are know to cause space-time deformation.
This fictional term gravity can be equated to chariots pulling celestial bodies across the sky.  Gravity as two bodies attracting each other, as you think of it, does not exist.
Think of the 2-D rubber sheet example above, then wrap your mind around a 3-D version of it.  You will then be able to start understanding aether and space-time deformations.
Can you visualize in the 2-D rubber sheet example, that you are sitting on Earth's surface and your TPU with it's rotating vortex,   and all of a sudden the cone on which the Earth is depressed starts deforming.  First a little dimple, then a long finger, then it gets bigger and wow, the rubber surface stretches and forms a cone right into the center of your TPU.  The TPU has synthesized a virtual mass so great that it deforms space-time.
So yes, gravity can be involved in the TPU, even though gravity does not exist.  ;)
Regards, Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
