TPU - General Discussion
Started by z_p_e, October 01, 2007, 11:32:43 PM
Esa Maunu
Quote from: BEP on October 08, 2007, 10:51:18 AM
Quote from: z_p_e on October 08, 2007, 09:26:56 AM
It boggles my mind. SM has already provided enough information and clues as to the underlying principle and folks either ignore it or are totally oblivious to it.
@Esa Maunu
Have you seen any of your statement proven or repeated parts on a work bench? (Now I sound like you guys when I came bursting on!)
All of what you say is old information here. The question is - Can you put it in practice and document all of it so others can benefit?
Also - I have a fair amount of experience with SEGs. I haven't found a one that worked or been able to reproduce a working model from the information available.
What I have found is that some of the theory pans out but most of it is a flight into theology.
Like i told you before, i am also working with magnetostrictive devices in a practice.
Yes, this is not a new information. I am trying to talk about this techonlogy before also here, but it is good that there is now more interest about this subject. I hope that the information is useful for somebody, who is trying to  build tpu.
Esa
BEP
@Esa
Thanks. I appreciate the detail you supplied and the references. I have always believed this is a root mode. I have not been able to confirm some of it to myself.
Please continue supplying relavant details.
@EM
I have found that longitudinal wave devices exhibit multiple resonance points. Please keep this in mind when going for feedback. These points are not always expected or have an apparent correlation with each other.
acerzw
@All
We must bear in mind that SM states he does not understand how the TPU works, just suspects that it is related to Schuman etc. presumably because of the orientation problem and because he states the fields rotate in the opposite direction when used in the other hermisphere.
Could it not be that the OU energy comes from the Suns energy entering the earths atmosphere, where it is then modulated by it?
I suspect the TPU gets its excess energy input due to more than one effect. If it was as simple as one source, it would have been figured out by SM originally, and by all here within a short time. I think the simplicity of the coil creates the expectation in people that it is a single effect that creates the excess energy. But the complexity of the field interactions and there results are probably outside the ability of but a few people on the planet to explain, this is exactly the problem Tom Bearden relates, you need someone who is specialised in some many technical fields...
Acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
devilzangel
From what SM says, compass gradually spins faster and then eventually stops, it is possible that this could be because the rotation field creates a deadzone at the center of the ring, not because the spin is too fast for the compass to follow. kind of like a hurricane.
also while we are talking about vortexes, it seems many of us are assuming the flow is "down" towards the singularity of a vortex. BUT what if this is not the case? Hurricanes actually utilize energy flow upward. either the cone is upright with energy flowing up to the ring from the cone's singularity; or the cone forms upside down with the singularity being at the top, and the energy flowing with the aether down towards the rings.
another way of thinking about it in 3 dimensions is the opposite of a black hole (a white hole), energy flowing out of a singularity.
here is more of what i am thinking; this whole tuning and resonance business might actually have the goal of either moving the cone up or down and thus aligning the cones flow to match with the rings, allowing for the ring to draw energy from this alignment.
thought i might just throw what i am thinking out there. most of you should be able to see what i am trying to say here. (let me know if you guys want me to put a drawing up here)
devilzangel
turbo
Quote from: z_p_e on October 08, 2007, 09:34:32 AM
Quote from: -[marco]- on October 07, 2007, 02:01:50 PM
hi  :)
as my memory serves me right there was also something about drawing a lens when velocity becomes extreme.
some people claim gravity itself is a electric/magnetic force.
i do not know what it is, but i do think it is convertible into another form or forms of energy.
is there anybody getting positive results or am i the only one seeing intresting things?
M.
Hi Marco.
What kind of things are you seeing and what is your setup?
i have a setup like a jet turbine.
when i put energy into the system, it starts to rotate, it also speeds up depending on the amount of energy i put in.
when i flip over the device and apply the same amount of energy ,it does nothing.
when i reverse the polarity of the energy i apply, it works in reverse.
the potential is concentrated exactly around the circumference so this would be the best place for the collector since i did not put one in yet.
i will try to do so comming weekend.
if my findings are correct the right rotation is counter clockwise horizontal and up vertical.
however im not totally sure because i do not see how these will slap each other...
the images i am seeing are becomming quite clear lately.
but i have this lonely feeling about how much people are actually trying to solve this puzzle by experimenting in stead of theorizing.
if i do find the awnser, i do not know how to proceed...
it's like it is laying in front of me, i only need to put it together, and this i can do anytime i want to.
M.
