TPU - General Discussion
Started by z_p_e, October 01, 2007, 11:32:43 PM
Grumpy
Quote from: duff on October 12, 2007, 06:46:55 PM
...because at the top of the thread he refers to ultra sound.
Longitudinal waves propagate like sound waves.
        -Frank Edwards
ronotte
Hi all,
@Whatsup
THANKS for the Litz link...really a lot of  goodies....I'm really happy.......I'll need to read it deeply and use it on line.
@Duff
1 - in my case I did 2 tests one with a 20mt Litz coil and one using a 500mt thin enameled wire coil. In both case the magnet (NEO) were sliding on top or coil bottom. If I operate the coil side I obtain very small effect. Of course is normal that if you take your heavily coiled bobbin in your hand (or slide your hand very near) it will do like an antenna...capturing mainly your body leakage 50 Hz. In my case I always stayed far from the coil and the background noise were about 20 millivolt in relation to 400 - 500millivolt due to mag swinging over the coil top.
NOTE: if I move the coil only  -->  NO EFFECT.
2 - it's funny you did not had a very good reaction with your high speed gtest (it is not that in the open TPU the grey side thingh is just a small DC motor?). I'll chek it as well but in an easier way: just how told by MACEDONIA CD. I'll report on this.
@Grumpy
OK about your suggestion to put the kick coil all over the ring: in my case it will be lumped in 3 spaces as other places are already fitted with 3 control coils. I do confirm that bandwidth for the small test prototype is from 30 KHz into megahertz range.
One point to note is that the output voltage is strictly following the magnet sliding on top of the test coil, so it's NOT A KICK but just a small DC amplitude variation with the time. With such an fdo I wonder if it can be useful to induce anything on exixting 90 degree collector wire!
SO HOW TO EASILY TRANSFORM A SLOW DC VARIATION INTO A KICK USEFUL FOR OUR PURPOSES?
@MACEDONIA CD,
The last question is also for you as it seems that you know it better: to summarize we do need a kick coil excited by the relatively slow hand sliding of a magnet and able to deliver at least one fast kick that in turn would be multiplicated by the induction into our existing Control coils.  As you have seen I did some tests on single wire and high coiled bobbins...but always using hand linear magnet sliding. OK i'll try next with hand movement of magnet around the wire...I'm just going to do it and I'll report the difference.  Anyway , doing by hand I'll have still slow DC voltage NOT KICKs....so the problem will be still opened.
Roberto
ronotte
Hi all,
@MACEDONIA CD
as previously said I just did the following test:
1 - I took a piece of 15 cm of Litz wire (40 threads) then kept it stright on two rigid supports and put scope probe in derivation.
2 - Set scope sensibility to 20 millivolt/div and slided by hand horizonthally  and then vertically my  1x4 x .5 cm my NEO magnet bar. RESULT = 10 mV noise steady - no activity indication on scope. Clearly the wire lenght is too short and unable to catch also the strong mag field coming in either way from the NEO magnet.
3- tried the same but revolving by hand the NEO around the wire: same result - nothing.
MACEDONIA:
"TOANDERSTEND MY ONLY YOU NEED SMALL PIECES OF WIRE ABOUT 5 cm THEN YOU MOVE PERM,MAG  HORISONTAL THHEN VERTICAL OR AROUND  YOU WHILL SEE THE DIFERENTS VOLTAGE  YOU MOST MOVE THE MAGNET WHIT THE SAME SPEED TO SEE THE DIFERENT BEATVEANE THIS 2 DIFERENTS MOVING OF MAGNET"
Why do you claim such kind of results?.....we have not time to loose. If you are on something please document it full like I do! I'll be first to congratulate. I'm much interested in obtaining KICKS : NOT SLOW DC VOLTAGE SWING.
@ all
I tried to put my NEO in my hand driller chuck and run it slow near the top of my 20 mt Litz lumped  KICK COIL: OK I've a very good sinusoid of about 0.5 V ptp (about 1 V or more using a bigger NEO). So if this's the way (open TPU perhaps uses a small DC motor to do the trick) how do you suggest to transform it in kicks without use of any electronics? (I tried to resonate the output but  for the moment no results....)
Roberto
wattsup
@Roberto
Good to see you like the links. I will put up some more on that same post. I just put another link showing Litz wire AWG versus frequency range.
For tests like MAC's, remember if the wire strands are in parallel this will increase amperage, if it is in series, this will increase voltage. So you may  be seeing low voltage but the amperage should be higher.
Looking at the video, I would take a guess to say the coil wire Litz is 16 AWG and according to the table for 6000 hertz (1khz-10khz range), it would be a 26 strands of 30 AWG wire.
Now the problem here is it could also be a 14 AWG which would make 42 strands at 30 AWG. I will look at this further to see if I can pick up any visuals for a better size comparison, etc.
One other major thing I have observed on the Coil #2, I think I am seeing a round magnet or a ferrit core or something else round that is taped on the outer side of the coil. I am putting two photo close-ups, one regular photo and one with britness adjusted to show this and maybe others can  get a better idea on what this may be. I am sure it is not the natural curvature of wound coil wires.
Sorry if I am putting these observations one after the other, but this video is really short and crappy and you have to spend alot of time looking and looking to see the small nuances.
So there could be one magnet on the side of the coil and another placed manually on top. Maybe the shifting action between of both fields is creating a field movement. Also, there could be another magnet on the inner side of the coil.
I am going to my favorite electronics  place to see if they have Litz so I can do some testing myself on this question. Not everyone sells Litz wire. I have seen some on ebay. When I saw this item I was thinking of Otto for this ECD rings.
http://cgi.ebay.ca/Litz-wire-175-46-coils-Loop-antennas-crystal-sets-100_W0QQitemZ300160862204QQihZ020QQcategoryZ26213QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
MACEDONIA CD
HI
i realy dont anderstend me in the england languege  if you able to make anderstend in my languege  i whill tell in my languege is easy way   , i read some reply of otto  is raid  way i have more ideas and more things  to make a road clears to make a move to this way  listen i now whill say in the macedonian lang..
ZDRAVO NA SITE  STO SE MI PRIJATELI  I NEPRIJATELI VAKA JAS SKORO SUM MNOGU VREME NA OVOJ FORUM I MISLAM E MNOGU DOBAR  I E LESEN ZA  KONTAKT
OVDE DRUGO IMAM MNOGU LUGE  STO SAKAAT DA IM SE POKAZE SO SLIKI ILI SO VIDEO CLIPOVI    DOBRO NO  I DA VI PRATAM DA RECEME  STO KE VIDITE    ISTO KAO I S.M DA GLAVNITE DELOVI NE SE GLEDAAT NO  SEPAK  JAS  SUM VO FORMA DA IZRABOTAM DOBAR TPU  I DA VI GO PRATAM   DA GO VIDITE DEKA E VOZMOZNAO DA SE NAPRAVI  TOA  STO  NAIZGLED LICI EDNOSTAVNO  NO TESKO DA SE SVATI  NO SEPAK E MNOGU EDNOSTAVNO  TOA KE VI KAZAM ,, IMA  2 RABOTI KOI SE MNOGU VAZNI ZA DA SE POCNE DA SE IZRABOTI NA SLICEN ONOJ NACIN KOJ GO IZRABOTIL DA RECEME <S.M > VAKA  1 -- KE POCNAM SO OVA  JAS KAKO STO SUM GO SFATIL SO GLEDANJE NA CLIPOVITE OD S.M  ISO NEKOI PATENTI STARI STO SUM  GI CITAL  SOM POTVRDIL DEKA TOA EDINSTVEN NACIN DA SE NAPRAVI TOA   I DRUGO IMA 1 DO 3 NACINAI DA SE NAPRAVI  SLICNO  KAO S.M TPU
SEGA
KOGA GO SLUSNAV DEKA SM KAZUVA   1 I OSNOVNO  DEKA  <<<  ZICITE NEGOVI STO SE VNATRE VO TPU SE MNOGU VAZNI  >> I DEKA  NAMOTKITE  KAKO SE NAMOTANI I NAKAKOV NACIN SE IZRABOTENI   ISTOTAKA SE VAZNI  I DA ZNAETE IMA GOLEMA VRSKA KAKO SE NAMOTANI   I E VO PRAVO S.M  SO OVA  KAZUVA VISTINA
DRUGO  ON KAZUVA VAKA    KREIRA ELEKTROMAGNET   SILA KOJ OVOZMOZUVA DVIZENJE NA ELKTRONI VO DRUGA NAMOTKA  << I VISTINA VI KAZUVAM U PRA VOE  TOJ>> E SEGA   TOJ NAPRAVIL 2  3   VIDA ZA DA NAPRAVI DVIZENJE NA ELEKTRONI
1  E SO MAGNET PERMANENTEN   A SLEDNIOT E  SO NEKAKOF  OSCIL. KOJ GSLUZI KAO START POTOA TOJ SE ISKLUCUVA ILI SE NADOPOLNUV
PRIJATELI
VAKA TIE SE OSNOVNITE RABOTI KOJ TREBA DA GI SVATITE VIE MOZE DA IZBERETE 2 NACINA KAKO DA NAPRVITE  NESTO STO KE GO STARTUVA PRIVOT UDAR ILI <<KICK>  I VTORO KAKO DA GI NAPRAVITE NAMOTKITE
DRUGO S.M KAZUVA DEKA NEGOVOTO TPU NE SE ZAGREVA MNOGU  A JAS IMAM I ZATOA ODGOVOR  ????  KAKO NESTO TOLKUMALO I TOLKU JAKO DA NE ZAGREVA E VAK
AKO NAPRAVITE VISOKA FREKFENCIJA MISLAM NA<< LM WAVE >> TIE BRANOVI ILI FREK. IMAAT SPOSOBNOST DA GI DVIZAT SLOBODNITE ELEKTRONI KOJSE NAOGAAT NA POVRSINATA NA ZICATA  TIE NE VLIAAT NA VNATRESNITE ELEKTRO ZNAETE DEKA VNATRESNITE ELEKTRONI AKO SE DVIZAT VO VNATRESNINAT NA ZICATA TOGAS SE DOAGA DO TRIENJE  NA ATOMITE I TOGAS U TOA DVIZE ILI PAK UDIRANJE NA SEKOJ ATO M SO DRUG ATOM  SE PROIZVEDUVA TEMPERATURA ,, SO OVA VI DOKAZUVAM DEKA S.M KORISTI BRZA FREKF  ZA DA NE PROIZVEDE OD EDNASTRANE TEMPERATRA A OD DRUGA STRANA  DA NE STAVA I DA IZBEGNE  MNOGU ZICA VO TOA TPU I POKRAJ OVA   IZATOA  TOA NEGOVO TPU NEMA GOLEMA TEZINA JAS PRONAJDO NEKOI NACINI ZA DA SE NAPRAVI OVA  VAKA  PRVO  DA NE ZABORAVEM DA VE PRASAM NESTO  DALI IMATA CITANO ONA PISMO KGA S.M MU PISUVA  NA <<MANNIX >>""""""" S.M PRAVEL EXPERIMENT SO 2 TRANSFORMATORA PROCITAJTEGO TOJ DEL  DOBIL NESTO MNOGU VAZNO  TUKA SO TOJ EXPERIMENT NAVODNO STO GO IMAL PRAVENO """"""VAKA  IMATE   NESTO VAZNO 2 DA NAPRAVITE A TOA KAKO DA IZRABOTITE MAGNETNO POL MISLAM JAKO MAGNETNO PO SO MNOGU SLAB ELEKTRICEN IZVOR ILI PAK PERM .MAGNET   SEGA KE VI KAZAM VAZNA RABOTA  I ZAPAZETE
DA PRATPOSTAVIME  IMATE MAL IZVOR  NEZNACI DEKA MOZE DA BIDE OBICNO TRFO MOZE DA BIDE BILO KAKOV IZVOR PA  I PER.MAGNET
ZA DA ME SFATITE KE VI OBJASNAM SO TRAFO   AKO TOA TRA  DA RECEME  IMA MAX.. SNAGA OD 1 WATT TOA TRAFO VO CENTAROT NA JADROTO IMA SI NEKAKVO SLABO MAGNETNO POLE  ONKVO KAKVO STO MU TREBA ZA DA PROIZVEDE SNAGA OD 1 WATT AKO STE UCELE ILI PAK ZNAETE DEKA  AKO IMATE NEKOJ MAGNET I GI DVIZITE OKOLU ZICA KE DOBIETE STRUJA NEKAKVA EPA SEGA KAKO DA NAPRAVITE DA GO ZGOLEMITE MAGNETNOTO POLE ILI PAK DA DOBIETE POGOLEMO MAGNETNO POLE SO TOLKU MAL TR.. OD 1 WATT DA RECEME TOA TRFO OD 1 WATT IMA MAG POLE 0,0001 TESLA   A
DA RECEME VO SPOREDBA  1000WATNO TRAFO IMA 1 TESLA MAGNETNO POLE  .... KAKO E VOZMOZNO DA NAPRAVITE TOLKU GOLEMO MAGNETNO POLE KA ZA  1000WATT TRAFO  A KORISTITE 1 WATT TRAFO  ,,,PRVO STO KE RECETE TOA E NEVOZMOZNO I NEMA SANSI ZA DA SE NAPRAVI TOA   E PA DRUGARI TOA E VOZMOZNO
DO TIKA KE ZASTANAM ZA DA VIDAM STO KE KAZETE
ZAKLUCOK
VI POKAZV KAKO TREBA DA SE NAPRAVI PRAVILNO MAGNET ZA DA DOBIETE PRAVILNO DVIZENJE NA ELEKTRONI SO CRTEZOT VI KAZAVDEKA IMA POVISE MOZNOSTI ZA SE NAPRAVI DVIZENJE NA ELKTRONI I VI KAZAV ZA DEKA SE MNOGU BITNI KAKO SE NAPRAVENI NAMOTKITE  I DEKA NEMA NISTO DRUGO OSVEN DA NAPRAVITE MAG ,POLE
I NAKRAJ  IMA EDNA FORMULA   TAA VAZNA
E= B * Q * S    E -- ENERGYJA ,, B--  MAGNETNO POLE ---  Q-- GOLEMINA NA ELEKTRON
                       S---  BRZINA
OVA MNOGU BITNA RABOTA I BITNA FORMULA   ILI ZGOLEMUVAS BRZINA SO NAMELENO MAGNETNO POLE  IL  ZGOLEMUVAS MAG. POLE   SO NAMALENA BRZINA  TOA E ISTO
SEGA VE OSTAVAM DA KAZETE NESTO  A NAREDEN PAT KGA KE ME SFATITE  KE VI GO KAZAM I ONA NAJGLAVNOT << START SO MAGNET >> I ZGOLEMUVANJE NA ELKTR. MAGNETNO POLE SO MNOGU  MAL IZVOR  TOGAS KOGA KE GO ZGOLEMITE MAGN. POLE SO MAL IZVOR TOGAS LESNO KE  JA PRIMENITE OVAA FORMULA
CEKA ODGOR I REPLY  POZDRAV OD MAKEDONIJA
