TPU - General Discussion
Started by z_p_e, October 01, 2007, 11:32:43 PM
innovation_station
hi guys
the open tpu has 4 control coils but are they hookd up in pairs? hummmm......
and fire 2 at a time 180 deg kinda like my 15" ring it has 6 controls and they could be hooked up this same way 2 controls coils fireing  @ the same  time and rotating around 120 deg each time they fire
ist
ha the more i write the more i think lol!!
ok how bout this if we are hooking them up in pairs ....   we should have 1 side of the pair go through a phase invertor so we have a + coil and a - coil comming on at the same time within the pair of coils or if our wave was the right length then the coils could be all 1 wire in 4 segments and the sine wave will be the phase invertor no?   hummmm.....
ronotte
Hi all,
@Whattsup
I think as well that the Litz does connect in series all the coils #1,#2 and #3,  it is to gain voltage..I'm not so sure about your coil structure extrapolation....it's really difficult!
I'm quite sure that there are batteries in the round can and SM did activate them..by pushing action......this is not to detract anything.
At this point perhaps you will be so kind to try to setup a dranwig: it could be a base for discussion  as it must be clear for all the references to 4 horizonthal coil for the rot mag field and the 3 vertical coils in the interconnecting bars (?).
@MACEDONIA CD
well I'm waiting for your detailed explanations/results as you have said. In the mean time I'll pulse my 500 turns test kick coil with or without a DC bias and I'll post the circuit setup and the scope waveforms obtained with a quick NEO movement  (I've a storage scope so I don't need to make a film).
I think I've understood what you are trying to say but...... all seems quite normal operation: still no explanations about kicks multiplication.....please don't tell me that is all up to the control coil!!! All the guys in this Thread, since a long time, are trying in every way to design  a proper coil....if you have found a concrete solution you are warmly invited to show it to us ...we will be happy!
Roberto
MACEDONIA CD
 HOW MANY TIME TO TEEL YOU FOR ALL IN THE FORUM NOW I MAKE SOME TPU JUST LIKE THIS I HAVE TOLD YOU   I MAKE SOME GOOD PROGRESS  NOW I NEED TO BAY SOME WIRES TO MAKE BIGER TPU   IM SO  AND I DONT KNOW HOW TO EXPLANE SOME SIMPLE THINGS HOW IS TO MAKE THIS
AGAIN
1-- START WHIT SIMPLE AND SMALL PUSH ENERGY THEN YOU  PUT THE CONTROL COIL TO THIS SOURCE ONLY ONE KICK OF PUT DC VOLTAGE SMALL  OR PER.MAG  ,, YOU DONT NOW HOW WHIT PERM .MAGNET
NOW I WHILL TELL YOU
LISTEN   MAKE MANY NUMBER OF TURNS  WHIT SIMPLE WIRE  WHIT SOME LITLE CORE INSAID THEN THIS WIRE  HAS 2 ENDS OF WIRE  IN THIS ENDS YOU CAN SEE IN THE OSCILOSCOPE  IF YOU BRING SIMPLE MAG.  THEN  IN THE MOMENT WHEN YOU PUT MAG.  YOU WHILL SEE IN THE SCOPE. DC VOLTAGE HO IS TAKE SHORT TIME  OK  THIS IS  HOW TO MAKE A SIMPLE SOURCE  DC VOLTAGE SMALL THATS IM ONLY NEED SMALL DC WHITT SHORT TIME
AND THIS SHORT IMPUSE GO TO THE CONTROL  COIL  ::::??{{{  THIS COIL  MUST BE MAKE IN THAT WAY LIKE  S.M IS MAKE  THAT IS LIKE THIS
LITLE EXPLANE ....  HIS VIDEO WHIT 2 MAG. AND 2 BULB   THIS TPU  HAS 4 COILS  * 2 IN ONE ALL THIS 4 *2 COILS IS CONECTED  IN SERIAL  WHIT 2 ENDS
THIS IS IMPORTANT
WHEN IS PUT 1 KICK  THEN THIS COIL PRODUCED 8 KICK  << LIKE  EARTH MAGNET FILD HO IS 8,7 Hz>>  ONLY ONE KICK FOR TO MAKE 8 KICK PER SECOND  HOW IS POSIBLE
IF YOU MAKE LARGE MAG . FILD YOU CAN HAVE MORE POWER IN THE OUT  WHIT THE SAME 8 HZ    IF YOU INCRESE MORE LET SAY 2 KICK IN  energy you can have 16 hz
but this is the periode when is put the surce is 8 cikluse  when you turn of the sorce you can have 16   wht frst on  then off input energy you can have 16 cikluse if you put just half  imen only on  then is 8 hz if you turn off you have anther 8 hz  and  you have sumary 16 hz whit only on and off  imean kick    . iIWHILL SEND  PDF  AND VIDEO SOON TO SEE MY FORK TPU   JUST  I HAVE TOLD SOME THINGS
EMdevices
Hi Guys,
I performed a number of exiciting experiments and got a bunch of cores to vibrate and resonate.
I then tried to tap these vibrations with pickup coils and a magnet (like a guitar pickup coil scheme)
I failed !!!Ã,  Ã,  No signal.
The vibrations don't have enough amplitude to generate a signal above the noise floor of my scope.Ã,  :(
Does this mean I'm changing my view point?Ã,  Not at all.Ã, Ã,
It is not coincidence that SM is operating the Open TPU at 6000 Hz, like we've seen.Ã,  It matches an acoustic standing wave. I was also watching the video again, and it's interesting, when SM mentions the "inherent vibration" of 6000 Hz, he circles with his finger around the TPU circumference, to show us its a ROTATION.
So, I'm thinking it's a bit too simplistic to just create vibrations with magnetostriction and then pick them up with a pickup coil and feed them back to the imput.Ã, Ã,
I believe SM is also employing ROTATION.Ã,  It could be that he uses a 2-phase rotational scheme, but again at 6000 Hz for that added acoustic resonance and it's benefits of OU.
In any case, these are exiting times, we're zooming in on the solution rapidly.
EM
BEP
@EM
Reporting either way is a great thing. I appreciate your effort. I wasted a lot of time trying to get results from the tiny movements. I was convinced I did something wrong until I just read your post. Maybe I didn't. It was probably the way you say on my bench as well.
And a big 10/4 on the rest of your comments!
