TPU - General Discussion
Started by z_p_e, October 01, 2007, 11:32:43 PM
wattsup
Here's another question but regarding simple pulsing.
If you had a small battery connected to a silent type integrated relay, is there way to make the relay latch, but when it latches it cuts the current to the relay to unlatch, but when it unlatches, it re-connects the current to the relay to latch, etc., etc.
Do you think this could happen 6000 times per second?
innovation_station
i think you can do that but i dont think that is how the tpu operates  :) but if you do this you can harness the spike or the bemf with some diodes and a cap  with ground source for coil   as cap ground source as well   ;)
is
turbo
Quote from: wattsup on October 15, 2007, 11:04:54 AM
Hi i think this could happen as fast as today's technology allows.
and i also think this is MUCH higher then the 6Khz you mention.
what did you have in mind?
M.
MACEDONIA CD
hi
ABOUT 6000Hz   IF YOU LOOK ANTHER WAY  FOR THIS 6000HZ  IMAGEN THAT LIKE YOU PUT ONE SINGLE DC IN ONE SEC.  AND YOU HAVE MOVMENT 6000 TIME LEFT  AND RIGHT MUVMENT OF ELK. MGNET FILD JUST ONE  HALF SEC
JUST ONE SEC ...THAT WHILL BE MORE THEN YOU PUT IN ENERGY IN ONE SECOND
THIS 6000 HZ  IS JUST MUVMENT OR I DONT HOW TO TEL L AND EXPLANE
JUST LIKE
IF YOU HAVE 50Hz  IN THE IN  THEN IN THE OUT YOU HAVE THE SAME 50Hz   look
IF YOU HAVE 1 let say 1 hz <<KICK>> and WHIT THIS  YOU HAVE OUT OF 6000 MUVMENT  8) 8) 8) I
IF YOU LOOK THIS  IS PERFECKT IN AND OUT ENERGY 1 =1  THIS
A SAID  IF THE 1 KICK MAKE 1 KICK OUT  ENRGY IS 1=1
WHEN  1 KICK IF YOU PRODUCED AND GIVE 6000 IN THIS MOMENT  AND EVERY KICK WHIILL BE LIKE IN ENRGY INOUT <<I MEAN EVERY OF THIS 6000 WHILL PRODUCED THE SAME SEPARATED KICK  1 AND AND3  .....6000
IN 1=1 OUT KICK
IN 1=2 OUT KICK
IN 1=3 OUT KICK ....TO 6000
YOU NOW IF YOU MAKE ONE COIL THEN ANTHER UP WHIT THIS AND ANTHER  AND ANTHE R THE MUVMEN THE SIMPLE MAG OR??? IS SEPARATED STORY
EVERY TURN I SEPARATED STORY OR INDEPENDET MAG OR ENERGY
IF YOU HAVE LIKE
I LAYER OF COIL  THEN ANTHER AROND THIS AND AROND THAT  AND ,,, AND.. EVERY SINGLE IS INDEPENDET OR ANTHER  CONCLUTIONS OF THAT IS THIS
1 KICK  PRODUCED 1 KICK  IN ONE LAYER OR COIL  THEN 1 KICK PRODUCED 1 KICK IN ANTHER LAYER OR COIL  ..
ALL OF THIS IN THE  SEPARATED TIME  I <<MEAN   1 SEC PRODUCED 6000
1 THEN 2 THEN 3 THEN 5 THEN 5  ALL SEPARATED  COIL INTHE SEPARATED TIME ONE ONE SECOND  IMAGEN  THAT
THE ENERGY IS THE SAME OF ALL SEPARATED COIL YOU HAV LIKE THIS
1 WATT IN  1 WATT OUT IN THE ONE COIL
1WATT IN 1 WATT IN THE ANTHER COIL
THE POINT OF THIS  IS HOW YOU WHILL MAKE  THE COIL JUST TO MAKE HAVE PROPERY MUVMENT  OF ALL COIL S IN THE  SEPARATED  TIME  JUST ONE SEC
1/6000
IN THE END OF THIS EXPLANATIONS  YOU DONT NEED ELEKTRONIKS   .. ONLY BATERY OR PERM. MAG   ONE KIC K IS YOU ONLY YOU NEED TO MAKE JUST 6000 JUST THE SAME LIKE ONE KICK
I THING YOU NOW WHAT IM SAY TO ALL THE ORDENERY TRAFO  PRODUCED  50 Hz in 50Hz OUT  WHIT THE SAME ENRGY IN THE SAME ENRGYNOUT  THIS
IS NOT ONE Hz is just to INCREASE SEPARATED ENERGY IMAGEN THIS  IN THE  ALL THIS  6000 HZ  YOU HAVE SEPARATED ENRGY ALL  IS THE SAME 1TO 6000
YOU PUT ONLY ONE ENRGY ,,KICK .. THIS KICK MAKE DUPLICATE THE ENRGY AND ALL THIS 6000 IS SEPARATED ENERGY
THAT IS ALL I        D O N T HOW E N Y M O R E   TO EXPLANE  I DONT KNOW ENGLYS  GOOD TO TELL TO ALL  IF   YOU CATCH THIS YOU KNOW WHAT IM SAID
@otto  WHAT YOU THING OF THIS  :o 1TO  6000 HA HA HA LITLE
LOOK VERY CARFULL  THIS   S.M <<<< TPU 700 WATT 6000 C >>> ONE KICK HOW MUCH WHILL BE ONLY ONE KICK HOW ENERGY  I SAID THIS  ANSVER
            O N E KICK IS     0,1166666666666666667 WATT  INPUT ENERGY OR KICK
  YOU DONT NEED BATERY ONLY PER. MAG  COLL STUFF  HA HA HA
EMdevices
Macedonia Cd, you're killing me man!!Ã,   LOLÃ,  :)
you got the most bizzare, long, and hard to read postings, I've seen, you win!!
Just show us that video lighting a bulb.Ã,  ;)
EM
