TPU - General Discussion
Started by z_p_e, October 01, 2007, 11:32:43 PM
innovation_station
it almost sounds like we want to use its self to induce a secondary of its self  use a magnet to produce a secondary electro magnetic feild witch we tap  but with out any physicial movement
so what might be the freq for the earth electro magnetic feild ? it seams like we disturb the first and harness the diffrences on the second and use some of the diffrences to refire the first
crazy talk
is
wattsup
@Grumpy
Funny you should say electrostatic. I was getting the feeling that the open TPU having plexiglass rings would have favored some electrostatic exchanges.
@Marco, BEP and also IST thanks for your comments.
Well, seeing as though I'm not worth two bits with the EE stuff, I decided to try this relay pulser which did work for a very good while but I finally blew two of the contacts. So I will try to get a few more maybe bigger capacity. I wanted to keep it in the 4.5 volts or less range to simulate 3 x 1.5 volts batteries, but I will do my further tests with maybe a 9 or 12 volt relay. I'll keep the pot thing in mind if I can understand it. lol
But I did notice that when I put a small coil the relay worked fine, but when I connected my 6" dia. x 4" high TPU mock-up of the 17er, having a center copper wire core and four vertical coils, set up like Ottos classic connection scheme (Hey it's a classic), the relay would not pulse. I think my relay was blew when I did this so maybe my TPU has too much power demand and is not leaving any power left to the relay.
I have realized by these small tests that whatever is used to drive the coils or collectors, given a finite energy source has to be well matched with the energy consumption for driving the coils. If the circuit takes too much, there will not be enough for the coils. If the coils demand too much, there will not be enough to the circuit. But I guess you guys know this already. Given this observation, having 3 coils with about 16 turns would be the maximum I would venture at such low votages.
I wanted to get away from looking at the video because I needed some time away to change my perspective. Looked only once at it last night and when SM pressed on that button I was laughing. Geez allllllllll this time went by and we only notice this now.
Tried finding Litz wire locally but all the places I usually go to "have never heard of Litz wire". Cannot believe it but it's true. So I will start buying some wire online and from a few companies. I will get some to also try as a Primary on my CBC. Hummmmmm.
By the way, look at this fat bugger.
http://cgi.ebay.ca/Inductor-15-mH-Litz-Wire_W0QQitemZ300160555083QQihZ020QQcategoryZ7288QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
Maybe not good for a TPU but at 7 lbs. it might be nice to have for future projects. lol
Anyways, while I get some Litz wire, I will make my own using 14-16 strands of some 29 AWG mag wire to approximate a 16 AWG wire. Just to do some small testing more along the TPU lines. What I want to indentify is the physical size of a magnetic field with a coil and two collectors as per the specs I gave earlier, based on varied voltage settings.
I would like to try pulsing the coils and measuring the collectors, but I will also try to pulse the collectors and measure the coils. This may be working backwards since you can have collectors with litz wire, taking half the strands to pulse one way and the other half of the strands to pulse the other way. This would produce to fields moving in opposite directions and by timing the pulses, they should meet at the vertical coil #3. Like when SM slaps his hands together.
I can't help but think when SM says "there is not much to this device", and when I look at the circuit inside the TPU, there is not much to it at all. There is basically 4-5 components. I'll post a blow up of as much as possible on the circuit soon.
Grumpy
In which video does SM slap his hands together?
        -Frank Edwards
epwpixieq-1
Quote from: duff on October 12, 2007, 10:22:32 PM
Quote from: MACEDONIA  CD on October 12, 2007, 06:54:24 PM
HI
TOANDERSTEND MY ONLY YOU NEED SMALL PIECES OF WIRE ABOUT 5 cm THEN YOU MOVE PERM,MAG  HORISONTAL THHEN VERTICAL OR AROUND  YOU WHILL SEE THE DIFERENTS VOLTAGE  YOU MOST MOVE THE MAGNET WHIT THE SAME SPEED TO SEE THE DIFERENT BEATVEANE THIS 2 DIFERENTS MOVING OF MAGNET   8) 8) 8)
Ok - I tried your test.
I used a 6 pole magnetic motor.
All magnets poles the same - North Poles facing out.
Rotor turning at 200 rpms
Connected scope probe to one end of 20cm copper wire. Ground not connected.
Held wire in both vertical and horzontal position by passing magnets.
I did not see much difference.
Please make a video of your setup so we can see what you have done
Hi,
Simple test performed with the idea from MAEDONIA  CD.
A clamp A-V meter ( it may be a normal one also ). An Ethernet cable ( well ... this what was in front of me at the moment ) and a Super Strong NdFeB 7/8X1" Neodymium Magnets, N42
Moving ( well ... quite fast up and down ) the magnet a long the cable generates voltage in the range of 40-60mV moving it ACCROSS the cable ( for sensible reasons only around 180 degrees ) sparks voltage in the realm 160-190mV. Sometimes the meters goes to Voltage scale but only 0.0 is flashed on the LCD so I can not confirm higher spikes ( this is not to say they are not possible ).
Regards to all,
acerzw
@all, gibber, gibber, gibber, froth from mouth etc....
SOR [Start of Rants]
Core Dump in Progress to tty1.
Rant 1 - Hardware is a distraction - What is the TPU's operating principle?
My gut tells me that SM's comments regarding the field rotating in different directions in different hemispheres, and the TPU not working upside down,  hold an important key which we are all missing!
I just know it, the key I think, lies in SM's more simple statements... about the TPU's interact with the environment, these must reveal the fundamental mechanism, since the energy comes from the environment... All the speculation regarding the exact hardware used is distracting from the discovery of the fundamental basics... So many clues... so little understanding by us all...
  • where is the energy from?
  • what type of energy is it?
  • which of the physical reactions SM describes, vibration, heat etc is fundamental?
  • which of the reactions is secondary?
The TPU is simple, the operating principle is likely very very simple... Once the theory is understood the hardware will virtually build itself, the hardware is not complicated...
Regarding the 'orientation' problem, it is clear that this problem is a key result of the fundamental operating principle of the TPU, it is clear SM changed the design of the TPU to detect its orientation and adjust the operation of the control circuit to compensate... but the 'problem' was still there, still a fundamental effect of the operating principle, SM just engineered a around it... it is this type of clue that will reveal the operating principle, environmental interaction, the exploding TV is another example...
So what fundamental operating principle, what energy, or field interaction, would be affected by the orientation of the device in relation to the earth?
Rant 2 - 'Rotating field? WTF!!!'
Maybe I am stupid but if I pulse a control coil wrapped around a TPU's main coil, the induced energy in the main coil must propagate outwards in both directions either side of the control coil.. symmetrical propogation... so it does not rotate... even if I then hit it with another blast from another control coil further around the coil... that will also propagate in both directions, particularly if it is at a different frequency.. remember SM's comment regarding Tesla and multiple flows in a single conductor...
Any rotation of any energy must therefore be purely a secondary effect, of some kind or interaction of the coil field with an external field, so why is it orientation sensitive (subtle link to Rant 1)... so you guys, why?
Rant 3 - Do TPU's still work?
Has it also occurred to anyone that the TPU's operating energy might disappear at cyclic intervals, how do we know that the TPU's in the videos are not being used a door stoppers because they no longer function? Some sources of environmental energy do this, for instance this is from the Borderland website:
UPDATE ON THE COIL / ORAC EFFECT -- 24 April l990
1. The COIL / ORAC EFFECT device was tried out in February 1989 and did indeed work, although the deflection was quite small. Several other variations of this device were tired, however none of them have indications of current which were any better than the original.
2. Around March of 1989, the Coil / ORAC effect began to diminish, and eventually "went dead". Different ORACs were tried, along with variations in wiring. Nothing seemed to make a difference. However, around November of 1989, I tried out the coil and galvanometer arrangement with a newly constructed 20 fold steel and fiber sheet box ORAC. The Effect was once again present, and back to levels of current readings corresponding to those observed originally. The Effect is currently active, and further experimental work with it is continuing as time permits.
EOR (End Of Rants)
Anyway some food for thought, I have my RGB rants off my chest now.... :P
Acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
