TPU - General Discussion
Started by z_p_e, October 01, 2007, 11:32:43 PM
Grumpy
We've been restling with these questions for a long time now.  ???
SM on "south of the equator":
QuoteYES NORBERT, WE DID TRY THEM SOUTH OF THE EQUATER, THEY WORK IN REVERSE. CAN SOMEONE
TELL ME WHY?
SM on Rotating field (notice he does not say a rotating "magnetic" field:
QuoteYES THERE IS A ROTATING FEILD WHICH CAUSES ELECTRONS TO FLOW IN COPPER WIRE AND BE USED TO
PROVIDE USEFULL WORK FORCE. THERE ARE MANY WIRES PERPINDICULAR TO THE MAIN COLLECTOR. THIS IS A NECESSARY PART OF THE DEVICE.
SINCERELY,
SM.
The rotation direction could be "influenced" by the earth's magnetic field.  This does not "imply" that the earth's amgnetic field is the source of energy.  In other words, TPU's still work on the equator.
        -Frank Edwards
innovation_station
i think the rotation ends up becomming our wave when the 3 freqs mix!!
and when it comes around it is like a light house on the water and the wave that is the coard or the light and makes our control /collector ringg
the wave is verry cool looking i will see if i can shoot a vid of this wave later on tonight i used nch tone generator to produce this wave using 3 freqs
ist
Bruce_TPU
@ acer
I think that trying to figure out "why" the TPU works is a fruitless venture.  SM said that they spent years figuring out that they could not figure out "why" it worked.
Now, obviously SM new "how" to make it work.  So working from this angle, and we attempt to figure out "why" it works, so that we can then figure out "how" to make it work, is an oxymoron.  ;)
Now, if I have not totally confused everyone, let me say this.  Tubes (amp) should be the thing to experiment with, because we know that it is one of the things of "how" to make it work.  Also, I am working on the Tesla Magnetometer angle that SM talked about, as to figuring out more of the "how".  If SM and company couldn't figure out the "why", and they knew the "how", there is no way we are going to either figure the "why", or figure the "how" from the "why".  :)  We can only figure out the "how", and that from both SM's specific instructions, and clues.
Cheers,
Bruce
turbo
Quote from: Grumpy on October 16, 2007, 03:32:09 PM
TELL ME WHY?
SINCERELY,
SM.
Hi
i was always thinking it starts with a rotating mag field, and then when the frequency's go up it goes into RF field rotation, which is transparent,the compass stops.
then it is not two wire induction but it will behave more like an antenna of a transmitter and the one on top of a car where the body is used as a ground connection.
basicly i was thinking this is what changes at a certain speed/frequency, and it also explains the interference around the device.
M.
BEP
"YES THERE IS A ROTATING FEILD WHICH CAUSES ELECTRONS TO FLOW IN COPPER WIRE AND BE USED TO
PROVIDE USEFULL WORK FORCE. THERE ARE MANY WIRES PERPINDICULAR TO THE MAIN COLLECTOR. THIS IS A NECESSARY PART OF THE DEVICE."
This tells me:
1. the rotation is part of the device
2. it is likely only one 'collector' is performing this key function he is speaking about in the above quote
What is doesn't tell me:
1. this rotating field is magnetic
