TPU - General Discussion
Started by z_p_e, October 01, 2007, 11:32:43 PM
tao
Quote from: EMdevices on October 03, 2007, 09:08:55 PM
Here's a better explanation of the OPEN TPU.
EM
Bravo, that is a really good synopsis there EM!
And HIGHLY PLAUSIBLE!
(merely summarizing what you said)...
Using fast/sharp pulses in the 4 control coils to induce fast physical movement to the lower ring (and hence the vertical output coils).
The OU component being the facet of free and very sharp movement of the lower ring due to it's own magnetostriction response ;), it then is this free OU component that moves the vertical coils to and fro in the field of the permanent magnets. This also explains the two sets of white wires that show up in the middle of that open TPU and go to the output cap there, always wondered where those wires were coming from...
I likey...
EMdevices
Oh my God, tao, check this out,
In the video he says he uses 6000 Hz
From the video it looks like the TPU has a diameter of about 16 cm
Circumference =  pi x 16 cm = 50.27 cm  =  0.503 meters
Now,
Assuming the approximate 3000 m/s acoustic speed in iron
wavelength@6khz = [ 3000 m/s ] / [ 6000 Hz ] = 0.5 meters
WOW  !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!    :o  :o  :o  :o  :o  :o  :o
Same result man,   he is using ONE FULL WAVELENGTH RESONANCE !!!!
What a confirmation, wow.  I'm hooked man.
EM
tao
Quote from: EMdevices on October 03, 2007, 09:44:10 PM
Now,
EM
Great minds..................
I was just about to guesstimate the diameter and measure against the 3000m/s myself, lol ;)...
Thanks for saving my time, hrmm, that seems like a PERFECT MATCH to the full wavelength resonance to me!  ;D
It is all just 'clicking' into place, it all fits. The kicks, having OU from a single wire, the frequencies mentioned by SM in his videos, the control coils perpendicular, everything.
I'm quite excited, to say the least.
Bruce_TPU
@ EM
Congratulations, my friend!  I believe that you may have solved the piece of the puzzle, where SM says:
"The frequencies are directly related to the circumference of the collector coil."
AND
"HEY, did you know that the frequency is proportional to the speaker's circumference? it appears that the frequency should change with the circumference of the speaker."
So, if this hold true, one now knows how to determine the fundamental frequency.  It is a good start.  Makes finding F2x and F3x alot easier!  LOL   ;)
I mentioned the math along time ago on my thread.  I believe it was called "directiviity" and it relates to speakers, if I recall.  You have already showed the math, using iron, and it sure seems to fit!!   :o  I mentioned iron along time ago also, but was quickly silenced by people quoting SM's copper stranded for the collectors, not iron.  But if it fits, ...  ;)
You may want to try your math with the larger TPU and see what frequency you come up with also, and see if it matches.
Edit:  Unless of course that is the F3x, then one works backwards to find the fundamental frequency as most here know.
Cheers,
Bruce
BEP
Following the same insanity....
If you lay the open TPU with the load connection South:
At SW, NW, NE and SE you have control coils (plate coils for the tubes)
wrapped over the control coils at NW and SE you have a grid coil (finer wire about 3.75 the inductance of the plate coil)
Coils at SW and NW are for the tubes at S
Coils at SE and NE are for the tubes at N
N & S hemispheres' coils are counterwound from each other (because feedback coils are usually counterwound? or each oscillator makes changes in the opposite direction?)
I'm thinking two separate blocking oscillators or magnetostrictive oscillators (either will follow resonance of the core AND the magnetic field environment) - not only to drive but also to limit.
STRIKE THIS>> And the bottom core/collector is a spiral wind to make maximum use of the magnetostriction effect.
I could go on but we'll see how that fits....
<realization>That is what the slit is for! To ALLOW for the expansion - How DUMB of me. The blasted thing is shiny black because that IS the normal color of annealed iron.</realization>
Sorry. I've already verified that what you say is actually happening - or could happen if that is how you build it. No OU here. And I do think you are right. The problem is I still think there is more to it but these should be solid basic operating principles.
