TPU - General Discussion
Started by z_p_e, October 01, 2007, 11:32:43 PM
innovation_station
anyone care to talk about the first bolt coil i made?? the 4"  the collector is 13'1" it is 10 turns of 18 ga speaker wire around a 4" peice of pvc soooo......
that tells us the resonance of the collector is 7.5 hz or any harmonic of that freq also bolt said that 10 turns for all collectors as a basic but can be more so we know a 7.5 hz wave fits into 13'1" wire just right what do crystals resonate at?!?!?!?! that to me is the second harmonic componment of the earth  ;)
but who the hell knows
@ all do we really need 3 amps?? or can we do it with just 1?
ist
anyone know what happins when we pluse a coil that is in resonance?
anyone know what happins when we pluse 3 coils that are in resonance??
now can our first freq put all coils in resonance???
yes i think it can throught the harmonics of the 7.5 pluse so once all coils are in resonance what do we have to do??
DISTURB IT ?!?!?!?!?!
UNBALANCE THE EQUALLIBERAUM??
hummmm.....
so why would tesla say he wished he never invented ac current ??
well because he discovered rotational current it is a much higher efficiency  ;) and hell it works from the earth  ;D
i beleave it is rotational current in our collectors and we are collecting the secondary of this  if this is the case the collector is our primary and has low voltage high current  so our feedback wind should match our collector to a ratio depending on our output voltage we want to achive bolt has said that we get 1 v / wind on out put the 800v tpu has 800 feedback winds or output winds some of thease winds must power the coil the question is how much power is needed to self power  so what do our fets need to operate and our freq gennys? hummmm....  well lets see if there were 3 feedback winds on the final wrap each feed back could be used to power each freq or coil @ a certian time acording to where it is wound will reflect the time where the next coil will fire
always thinking  well most of the time :D
acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
wattsup
@Acerzw
Thanks for that interesting read.
@all
This link is one pargraph but the last sentence jumped out at me so I thought I would put it up for some discussions.
http://hendrix.uoregon.edu/~demo/Demo/E_and_M/Capacitance/index.html
Also, I am still in the process of finalizing my diagram of the open TPU. I wanted to take some more time to get the most out as possible.
Regarding the small metal box that has the two wires going out to the lamps. I think this is a simple EMI Filter where the output of the TPU goes to the plug side and the side that usually goes into a circuit is simply going to the lamps. Most EMI filters are cromed on the outlet side, but i did notice that those which also had a voltage selector switch had the output end totally made of black plastic, so it is easy to cut the sections apart to only use the EMI filter having a black output end.
I am still stuck on the actual wiring directions which is painstaking to see, draw rough, re-follow, etc. Hopefully this will all come together by Monday night.
All the best.
acerzw
