TPU - General Discussion
Started by z_p_e, October 01, 2007, 11:32:43 PM
John M
Hi Acerzw,
Very good write up on stage one and two of the TPU. One thing I have a question is why the Control Coils have different number of windings and gauge of wire for the primary as compared to the secondary?
John
z_p_e
Robert (acer),
Nice to see you finally starting to see things the way they are....good post a couple pages back. Too bad not many others have also.
Only point I will correct you on however, is the use of BEMF spikes. Don't let anyone tell you strictly that there is ou in BEMF (inductive kickback is the correct term) spikes. It is not true, or at least not in the sense that just because the kickback can be used to increase voltage a substantial amount, there is ou invloved. In an ideal world, you would get back from kickback an amount equal to what you put in.
If it is true that there is ou the moment electron flow occurs in a wire (or coil perhaps), then it is also possible that ou exists in the kickback as well. But why do you mention kickback?
If you read one or two of the statements SM makes regarding the kick, you will notice that mention is never made of kickback, it is always initial electron flow. As I tend to be a purist, I would start there, not at the kickback.
Darren
turbo
Darren,
Just suppose Steven is right (afterall he did it) and there is a tiny amount of OU in the initial electron flow, and maybe there is also a tiny amount in the inductive kickback.
(and if it isn't in the inductive kickback, we can use this to generate another initial electron flow so again it will be there, as i hope you can follow this)
Suppose we are able to extract the both of them and we can recycle the energy resulting in a cop infinity system.
But we would be dealing with this tiny amount only so what do we do?
We make it happen many times to get to greater values....
Kick on Kick on Kick and release them all into a massive Inductive Kickback.
The Bemf like spikes are the ones we should see comming from a working TPU exept in the size and quantity as to give a greater voltage.
Storing the energy in a rotating magnetic field would result in a build up of energy and a runaway situation as the TPU does.
We only need to drive it up to the point where the gain overcomes the losses and the system will begin to feed itself, Catalyst.
Next step is to keep it there and not to go any further, Disaster.
Switching times are critical as all the energy between the initial electron flow and the inductive kickback are LOSSES.
the "on" time should therefore be as short as possible and so it does rely on how fast we switch on aswell as how fast we switch off the coils.
I personally believe there is no switching technique that comes close to the actual event of the inductive kickback itself, it manifests as the release of all the energy present in the field, at once, like an implosion.
Marco.
innovation_station
nice  ;D
just about there are we ?
well break time 4 me
i have some verry important work to do  and its not the tpu  ;D
i guess it is time to work out my ou generator cores  ;D
l8r all
william
@ raymond
it almost seems like i know you for some reason
@ the rest of u
how many of you are in the originals?  i dont expecxt an answer but i can think of 3 or 4 that were
why do we make this last sooo long ?!?!?!?!
you all know this device will only work for a short time DO YOU NOT!!!  AS IN 2012 !?!?!?!?!
COME ON GUYS up it........ i said this b4 i will be releaseing my machine and its inner workings verry soon i really hoped the tpu would be finished b4 this time comes i have had all of my materials for my generator for just about 2 weeks but left it alone to work on the tpu but with the laque of help made this job difficult for some one like me with almost no electronics experience i tried my best that i could all along but with little secucess but it is ok cuz the next phase of people can continue on the progress
but what if there is a trick that allows ss to work easly i bet there is   ;) sm said it would be difficult not IMPOSIBLE  to get the ring to work on ss outside the ring  what if it really dosent matter?!?!?!?!?!
hummm....
ist
z_p_e
