TPU - General Discussion
Started by z_p_e, October 01, 2007, 11:32:43 PM
acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
z_p_e
Robert.
Bedini's system utilizing LA batteries and inductive kickback may indeed set up a negative resistance effect which enables ou generation. Don't count him out.
However, aside from this application of inductive kickback, just harvesting it electronically, will not yield ou.
The Bedini "Scalar Beamer"  is indeed his Clarifier patent. I had built one a few years ago, but as of yet not done too much testing with it. I was mostly interested in the "biological effects" at the time ;)
Just wondering how in your opinion, scalars and pyramids are connected?
You are no doubt familiar with the famous photograph showing the DNA like emanation of "something" from the tip of a pyramid being excited by a Tesla coil inside?
Cheers
wattsup
@z_p_e
How are you.
Listen, since you seem to be the current resident EE could you please look at this and let me know if this will work. Please don't laugh at my elementary method of explaining.
I have put a small diagram as simplistic as it may seem portrays the elementary way that I can describe what I am thinking in the EE sense. So please bare with me. The connections may be wrong I know, but it is only to get an idea across so hopefully it would have done just that.
In the diagram below, I have a transistor that is energized by a control coil, not by an outer voltage source. When the on/off button is put to on, the battery will energize field coil, that will energize control coil that will open the transistor connection to the field coil, as control coil loses its charge it will close the connection of the transistor to the field coil and this can go on and on. Is this viable. If it is, then I think from there I can make a TPU.
What I am trying to drive at is the open TPU control system has to be so simple that the operation count should be not more then 3 steps, and controlling all these steps should not require more than 6-8 components. If I am to refer to the open TPU circuit board and with what I have seen so far, there are two four-legged transistors (white) there is one variable capacitor, there are a few resistors or diodes or small capacitors and that's it. I am very skeptical to seeing anything that could potentially pulse a specific frequency. I think the resonance is achieved only by the variable capacitor that will adjust the pulsing speed off the control coils. There are no heat sinks.
This control circuit is so elementary that it could probably fit perfectly in most of Tesla's simpler patents.
I think the control is not achieved by the circuit, but by the natural charge discharge of the coils that play with each other around a few transistors. If possible could you  please correct the diagram so i can make a few builds for testing.
Keep well.
Grumpy
The TPU is a "conversion device".
Is this a reference to converting between two types of energy?  Two different aspects of the same thing?
        -Frank Edwards
z_p_e
Wattsup,
I'm a little confused by your drawing.
I would encourage you to use only graphics of SPST switches in place of transistors to help eliminate any confusion. Your ON/OFF switch could also be represented by this same graphic. Just use a dotted line to control the switch similar to how I showed in the attached drawing...(remember the Mike WM?)
I think I have an idea of what you are getting at, but I'd hate to give you some advice until I understand better what you are trying to depict exactly in your diagram.
Darren
