TPU - General Discussion
Started by z_p_e, October 01, 2007, 11:32:43 PM
wattsup
@all
Hello and hope eveyone is well.
I have finished my document on the Open TPU (OTPU) and have put it here for reference. It does not get into heavy discussions of operation. There is one simple theory at the end. The doc mainly describes the componets of the unit as they are and helps all to understand how it is made, not what it does per say.
So enjoy and if there are any flagrant corrections, please advise and I will make the change(s).
All the best.
Motorcoach1
@wattsup - very well thought out document thank you. at the end about the theroy, yes i agree about the windings in the 2" and 4" tpu's the windings are loose as SM did state in the vid , at this point I wondered too as if he wasn't sure if the windings needed to be tighter , due to them moveing (vibration). I do agree that tecnicaly it has been over done , but this because testing is inevadble in figuring out how it works, as SM stated he didn't know and he had built a lot of coils that didn't work or ran and stoped running for some unknowen reason. I really like your idea about the static field being unique to that piticular TPU , the propagation of the electron field is importaint for operation. as the the harmonics I would guess the the circut board is a tone generator being pulsed , the Question is what tone mmm possable ( A sharpe ).....
acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
wattsup
@Acerzw
Thanks for your comments. There is an addition to this pdf that I am putting here. It is an extension to further push the question of collectors and the control coil.
I am going to get some Plexiglas or similiar material to do some rudimentry testing.
Motorcoach1
@ Wattsup- I did some testing on this a while back , playing with what Otto came up with. I had very good results but not substaining. I guess I mistook this as the magneto effect and dismissed it. seeing what you came up with brings on a new light to the appratus. the LED sequencer set up runs at 4khz to 5.7 depending on what seed you set it at , seeing this it just might work. I'll be putting the appratious back together and see what results i come up with - even if there small it's still results. Thank you for the new coil setup drawing , I'll go by this drawing. I keep looking at EM's cleaned up photos and the small coils just look so fimilar to me but can't remember where i saw them , it will come to me. even if the sluged coils with the ferrit removed this might work here ( air coil chokes are operated at a higher frequency that a ferrit core) . thanks again for the hard work Mike
