TPU - General Discussion
Started by z_p_e, October 01, 2007, 11:32:43 PM
acerzw
@z_p_e, tao, BEP & all
Please see this post:
http://www.overunity.com/index.php/topic,3279.msg53042.html#msg53042
and then my subsequent post on that thread, I would appreciate your comments on my idea for the main coil construction.
Kind Regards
Acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
Bruce_TPU
Thank you Mannix.
I believe that little bit of information is very helpful and I had not heard that.  Thinking of it this way, vibration can be cause or effect, or both.  If it were simply the by product of what was going on in the TPU, one would think that damping those vibrations would not make any difference, or perhaps only a small one.  If the operating principle were dependant on those vibrations, at 7.3 times a second on the small unit, the one could easily see why liquid damping would be a disaster.
That would seem to limit the possabilites somewhat to the motis operendi of the TPU.  It would also suggest that he was looking for the vibration effect (as in Marco's dancing magnet experiment) found close to the Shummans to further the power output.  It is mentioned by a person who attended a demonstration, that he "tuned too" 7.23 Hz.  Of course he used high frequency for the F!,2 and 3.  Thus the conundrum.
Bruce
acerzw
Might not the water also cool the coil and thus reduce whatever effect is being used, which would of course reduce the vibration as a secondary symptom...
Acerzw
z_p_e
Acer,
You should have the full story before bashing SM around. Give the man a break folks! Yes he was profusely "warned" about divulging TPU information....we should respect the fact that he continued to do so regardless, albeit in a metaphoric manner, but much better than nothing.
I am really tiring of seeing negative remarks about SM and the TPU. IMHO, if folks have these kinds of doubts about an inventor, they should move on to something else. This is certainly what I do. SM's and UEC's apparent motivations are of no importance to the end goal. Things are the way they are, like it or not. More clear info would be nice, but that's a given. Let's focus on understanding the TPU, and not on why SM did this or didn't do that.
Regarding your build theory and Ronotte's analysis; I have always seen and assumed that the two solid white areas at the top and bottom of the cutout section were wood formers. So, I have no comment regarding the material/layout theory.
Cheers
Esa Maunu
Quote from: Mannix on October 05, 2007, 04:51:57 AM
I remember when it was mentioned that when a running tpu was put in a bath of water it was a complete disaster because  in the air some give to the vibration is allowed and the water did not allow it.
a very interesting discussion here.
Hi Mannix,
Do you have more information what happened when tpu was put in a bath of water?
Electrons magnetic moment in a external magnetic field causes a precession that is similar to water vortex effect caused by gravity when water flows in a tube downwards.
Magnetic force is a flow of dark energy ( zpe ) and is a static field. If we are able to wobble electron spin precession with a current pulse, we can have energy from zpe, energy from spin flips, when electron precession is aligned again to be parallel with an external magnetic field lines ( zpe flow ) during pulses.
Esa
